Brand new G2 front 44, should it be sleeved? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 1st, 2013, 07:16 PM   #1
gattaca37
gattaca37's Avatar
Default Brand new G2 front 44, should it be sleeved?
Have a 03' rubicon that I'm putn a g2 front 44 in. I am lookn at 5.13 gears and am goin to C gusset it. Should I sleeve it? Runnin 36-13.5-15 iroks on 15-12 bead locks. Also, being the factory locking system is an electric air actuated what is the better choice, arb air locker or eaton electric locker? What advice can u give. Thank you
R G2 good axles?
gattaca37 is offline   Reply With Quote
Old April 1st, 2013, 07:40 PM   #2
joe_jeep
welfare wheeler
joe_jeep's Avatar
sleeve it! arb is about the strongest you will find. the rubicon air system will not run an arb though. factory air pump is 3 to 5 psi. arb takes way more than that. g2 axles are ok. not surerior evo stuff, but decent.
Old April 2nd, 2013, 02:49 AM   #3
gattaca37
gattaca37's Avatar
Is the factory locker a locker I should reuse in a new housing 44 or the G2 with arb is the way to go. Is the factory locker a strong locker or weak compared to arb? this is a 03' rubicon.
G2 is runnin a deal through 4wheel parts $200 off. I can get axle with arb locker for $2600. So what do I have to do to run the arb system? Am I able to retain the factory toggle switch which controls the front locker? Install an arb compressor and wire it to the factory toggle?
Page generated in 0.14312 seconds with 32 queries
