Disable Passlock system on 1999 K2500 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 1st, 2013, 11:29 AM   #1
MilwaukeeF350
Dan
Default Disable Passlock system on 1999 K2500
Long stories I bought 1999 GMC K2500 for plow snow. Had issue with key ignition it was hard to turn.
I end swap with junkyard steering column from 1997 K1500 they look exact. Right now it only run for 1-3 seconds then died.
I really want bypass that passlock it drove me crazy. 3 hours of try reset by do 30 mins relearn procedure.
I notice security light flash like 2-3 times when you turn key ON then it went off.
I read that you could bypass with this one but I wasn't sure if it will work for K2500? http://www.bergerweb.net/PasslockFix/
Old April 1st, 2013, 11:37 AM   #2
in2deep
Hole tester
yes if the oem keys hav a black resistor in the key then that will work
Old April 1st, 2013, 12:02 PM   #3
MilwaukeeF350
Dan
Nope it just normal key it had sensor thingy inside key cylinder I can see.
Old April 1st, 2013, 12:09 PM   #4
jerm97xj
I fixed it!!!
jerm97xj's Avatar
Did you swap the passlock sensor (ring thing) from the original column to the new one?
jerm97xj is offline   Reply With Quote
Old April 1st, 2013, 01:59 PM   #5
MilwaukeeF350
Dan
No since key cylinder from original column are trashed.
Old April 3rd, 2013, 10:20 AM   #6
RADRICK
RADRICK's Avatar
I heard that there is a way to wire in a resistor to tick the system on some, pass key systems. You could have the pcm programmed to drop the pass key, or can take the truck to a dealer to have them reprogram/relearn the new ign cyl.
Page generated in 0.16086 seconds with 41 queries
