12v Cummins - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 1st, 2013, 09:46 AM   #1
73f250cummins
73f250cummins's Avatar
Default 12v Cummins
Can you run a programmer or a chip on a 5.9 12v cummins? If so which should i buy?
73f250cummins is offline   Reply With Quote
Old April 1st, 2013, 10:43 AM   #2
disturbedsledneck
disturbedsledneck's Avatar
12 valves are all mechanically fueled.. No electronics.
disturbedsledneck is offline   Reply With Quote
Old April 1st, 2013, 10:47 AM   #3
in2deep
Hole tester
what pump do you have
Old April 1st, 2013, 12:17 PM   #4
73f250cummins
160cc, i didnt think you could i was just making sure.
Old April 1st, 2013, 09:04 PM   #5
in2deep
Hole tester
p pump or the old rotory
Old April 2nd, 2013, 02:41 PM   #6
69-power-wagon
69-power-wagon's Avatar
94-96 I take it. Because I'm pretty sure those are the years that came with 160 pumps
69-power-wagon is offline   Reply With Quote
Old April 2nd, 2013, 02:46 PM   #7
jerm97xj
I fixed it!!!
jerm97xj's Avatar
I think you can do a few mods to the pump and gain a bunch of HP AND MPG...
I was told you should install an EGT, boost pressure and fuel pressure gauge BEFORE you do that mod tho.
jerm97xj is offline   Reply With Quote
Old April 2nd, 2013, 02:58 PM   #8
OldSoldier
OldSoldier's Avatar
Look here
http://www.performancetrucks.net/for...ummins-343676/
.__[______]
|¯----O|||||O
()_)¯()_)¯\/¯()_)
OldSoldier is offline   Reply With Quote
Old April 2nd, 2013, 07:27 PM   #9
73f250cummins
Yah its a 94, cause i think they went up to a 175 or 180 cc pump not 100% sure on that. I Know you can get a Big pump i was looking at a 500cc pump as i plan on using it for a pullig truck
Old April 3rd, 2013, 12:29 PM   #10
69-power-wagon
You can get a lot out of your 160 pump. Buying a different pump isn't really necessary unless you're planning on going crazy with the power levels. There's a long list of things I would do before I would drop a couple grand on an aftermarket 12mm or 13mm pump. Also where are you located at in sw Michigan
Old April 3rd, 2013, 05:44 PM   #11
73f250cummins
Scotts, and yah im planning on going extreme on the horse power
Old April 3rd, 2013, 11:16 PM   #12
bighroder
bighroder's Avatar
I don't mean to talk down on you or anything but it sounds like you need a couple weeks worth of research before you do anything with the motor if you didn't know it was mechanical pump or how it works your going to be throwing money away trying to build a motor become firnilair with the motor and it'll save you allot of money as a person that is part of the diesel community we need more educated ppl that can defend the cause not iliterate ppl that just want to blow smoke. You said puller? 2.6, 3.0, mod ? What class's do you have local what are your needs from the truck? You won't have a 3 class truck that is well manored for the road. You also won't have the Need for 500cc of fuel just trying to save you a bit of money and maybe some stress
bighroder is offline   Reply With Quote
Old April 3rd, 2013, 11:21 PM   #13
boggin-machine
boggin-machine's Avatar
if you asking if you can put a chip on a 12v cummins i really dont think you should get into building a pull truck or have the capabilities of doing such a task.
Old April 4th, 2013, 12:21 AM   #14
69-power-wagon
Alright I just noticed that you started this thread on April 1st. Is this a joke or do you really need some advice? If so I would be more than happy to answer a few questions you may have.
Old April 4th, 2013, 08:27 PM   #15
73f250cummins
No it was a serious queston I no it has a mechanical Pump. I just wasnt sure if you could chip them or not. Im not fimilar with a cummins. I drive a powerstroke for a daily driver those i know alot about. I dont want it to be a strict pulling truck so no not a 2.6 or 3.0 I just want to have the power for when i take it to pulls.
Old April 4th, 2013, 09:04 PM   #16
bighroder
bighroder's Avatar
If you kno alot about the powerstrokes you wouldn't own one...words from a diesel mechanic... Me
Old April 4th, 2013, 10:02 PM   #17
Lousypirate
Whoop Whoop
Lousypirate's Avatar
x2
Go to cumminsforum.com and read the sticky threads under the 12v forums and just read and read and read.
Upgrade your trans first if you haven't done that already. Add gauges too.
The Kernel (46 CJ2a)
Wow, i would lick those...
Old April 7th, 2013, 11:35 AM   #18
73f250cummins
ok, whatever. Not what ive heard from the local shops.
Old April 7th, 2013, 12:27 PM   #19
Lousypirate
Whoop Whoop
http://kalecoauto.com
This place has everything you will need to get the power you want.
Old April 7th, 2013, 12:47 PM   #20
bighroder
bighroder's Avatar
They keep our shop busy that's about it Ford's really don't have anything going for em beside their d60s you want a good truck? Buy a Cummins put in a kingpin Dana60 you won't have troubles if you buy a manual. In all seriousness I work on diesels every day Iwould never own aFord not because of brand bias gov bailout or any other thing ppl say is their reason you want good fuel econ get a pre emission duramax you want power and reliability buy a Cummins. Ps you can't always listen to hear say unless you know someone at the shop they might be shittin ya. But if you have any questions need any help don't be afraid to pm me 12v is my specialty :)
Page generated in 0.59802 seconds with 83 queries
