04-08 F-150 Leveling Kits - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 29th, 2013, 08:54 PM   #1
fordbronco
the ocean called
fordbronco's Avatar
Default 04-08 F-150 Leveling Kits
I am thinking of a leveling kit for my 06 'screw 4x4. Anyone out there have any experience with brands, height of kits, polyurethane or metal spacers, etc? I'd like to clear about a 33" tire with stock rims. Just a rough idea at this point, however.
Old March 29th, 2013, 08:56 PM   #2
Toyfish
Toyfish's Avatar
Zone makes a nice poly spacer leveling kit and i can clear a 33 with it
Sent from my DROID X2 using Tapatalk 2
Old March 29th, 2013, 08:59 PM   #3
IDIeselman
IDIeselman's Avatar
http://autospringcorp.com/ is the best out there. 2" will be perfect for 33's while maintaining enough clearance between the spring and UCA so they do not hit on extension.
Old March 29th, 2013, 09:04 PM   #4
fordbronco
the ocean called
fordbronco's Avatar
What's the deal with the poly spacer kits vs. the iron/steel spacer kits? Do the poly kits compress by quite a bit?
Old March 29th, 2013, 09:43 PM   #5
BigBird
Duck Shootin' Wheelerer!!
BigBird's Avatar
This... The top and bottom are slightly misaligned to allow for this to happen. I would think the poly ones do not work that way.
I have a 2-1/2" autospring spacer in the front, and a 1-1/2 to 2" add a leaf in the rear. I can clear 35" tires on 18x10 rims with a -12 offset.
Had slight rubbing at the rear off the fender opening. I massaged it with a BFH, and all was good. Just sold my 18" moto metals.
Put my 35's on my stock FX-4 rims. I also just bought some 17 x 9 Ballistic 811's, but have not decided what tire to put on them yet.
Cheap Thrills Off Road
Old March 30th, 2013, 11:37 AM   #6
fordbronco
the ocean called
fordbronco's Avatar
[QUOTE=BigBird;3356448]This... The top and bottom are slightly misaligned to allow for this to happen. I would think the poly ones do not work that way.
BigBird, what was the stance your truck look before the aal in the rear? I like a small nose up look.
Very nice looking truck, btw!!
Old March 30th, 2013, 12:02 PM   #7
jbsjunk
Little Member
jbsjunk's Avatar
We use Readylift at work. Does a nice job.
http://www.readylift.com/c-213-ford-...wd-4wd-25.aspx
Old March 31st, 2013, 02:12 PM   #8
fordbronco
the ocean called
fordbronco's Avatar
Any one of you guys have a significant gas mileage drop with a leveling kit and bigger tires?
Old March 31st, 2013, 05:16 PM   #9
BigBird
BigBird's Avatar
It was pretty flat. The only reason I added the leaf in the back was because I didn't want it to look like a early 90's dodge 1/2 ton with five flakes of snow in the back when I put a 4-wheeler, motorbike, or snowmachine in it...
Thanks for the compliments... I likes my truck!
That is the reason I am called BigBird... my 2 year old daughter said "Daddy your truck looks like Bigbird!" when I got it...
Old March 31st, 2013, 05:24 PM   #10
BigBird
BigBird's Avatar
Bigger tires and higher in the air are going to bring the suck as far as mileage... I had the computer reprogrammed for better mileage and to correect my speedo and shift points, and it kinda got better
With the Chrome rims and the 35's, driving like a mature person, I got 16.5 miles per Imperial gallon... 1 IMP gallon = 1.2 U.S. gallons
I think that is close to 14 mpg...
Page generated in 0.22398 seconds with 53 queries
