vulcanizing a sidewall - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 18th, 2013, 06:20 PM   #21
Tab
Tab's Avatar
Not sure radial tires can be fixed in the sidewall area. I've had a couple bias fixed in the sidewall without issues. The key is "Offroad use only".
Old April 18th, 2013, 06:29 PM   #22
joe_jeep
welfare wheeler
joe_jeep's Avatar
i have used the semi truck type plug/patch on radials with success.
gotta be a small damaged area.
Old April 18th, 2013, 06:49 PM   #23
Gunsworth
Gunsworth's Avatar
I looked into this years ago (500 miles after buying my bfgs from cheapest place i could find) when i sliced a sidewall open. Now i have a cool coffee table on my deck, and only buy tires from discount now with full road hazard. I get a new tire every 6 months or so between my vehicles. Buuuut discount seems to be wising up and keep adding more exclusions to the warranty...
Bottom line, buy a new tire amd make a table with the old one
Old April 18th, 2013, 08:45 PM   #24
2fst4you
2fst4you's Avatar
Replacement tire is $330 and with the rest of tires only having 50% tread its not the route id like to take. They said its too close to the bead to fix
Old April 18th, 2013, 08:45 PM   #25
2fst4you
2fst4you's Avatar
Haha that's an idea
Old April 18th, 2013, 09:31 PM   #26
Gunsworth
Gunsworth's Avatar
Wtf why are they so much, because of the 16" rims? Ill be going goodyear (was just quoted 1050$ otd for 35" mtrs) with my next set, im done with bfg, nothing but problems with every type of bfg ive owned...
And if they are at 50% then i dont blame you, sell em as spares...
Sucks, but not much you can do...
Old April 19th, 2013, 06:06 AM   #27
2fst4you
2fst4you's Avatar
I love my km2s although I'm disappointed the sidewall failed. Ya 4 have about 55% and one about 65-70%
Ya the 16" wheel makes them pricey. If the sidewall can't be fixed could I put a tube in it?
Old April 19th, 2013, 06:33 AM   #28
Suta99
Suta99's Avatar
Of course you can, you can also buy a 50% tire for less than $100 and actually be able to trust it.
Old April 19th, 2013, 10:03 AM   #29
2fst4you
2fst4you's Avatar
Can I run a tubed tire on the street or on the trail with low pressure?
Finding a 315/75/16 km2s is near impossible
Old April 19th, 2013, 08:42 PM   #30
littletrucker
I'd hit that
littletrucker's Avatar
You can do both, I couldnt recommend running a tube in a tire down the road at low pressure however, that would generate a lot of heat. More than likely causing the tube to fail.
Tire rack has them in stock....
Old April 19th, 2013, 08:50 PM   #31
joe_jeep
welfare wheeler
joe_jeep's Avatar
coat the tube heavily in grease b4 you install it.
dont run low pressure at high speed.
you can patch or boot a tire b4 the tube is installed.
Old April 22nd, 2013, 10:18 AM   #32
2fst4you
2fst4you's Avatar
The tire will only be useed for the trail. How do i go about patching it?
Old April 22nd, 2013, 10:38 AM   #33
I suck cocks. Lots of them.
locally famous
Grease? Why?
Page generated in 0.28680 seconds with 62 queries
