D60 leaking - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 26th, 2013, 11:28 AM   #1
firehawk
Live Action!
firehawk's Avatar
Default D60 leaking
The front 60 in my Jeep is leaking at both side. Is this an indication of worn bearings?
Should I get the whole rebuild kit or just put inner seals in it?
What to check for if the bearings need to be replaced?
I have seen the inner seals for $30-$60 a piece. A whole rebuild kit from Yukon is $210 shipped.
Old March 26th, 2013, 11:45 AM   #2
Bones
Bones's Avatar
what axle?
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old March 26th, 2013, 12:26 PM   #3
firehawk
Live Action!
firehawk's Avatar
Originally Posted by Bones View Post
what axle?
Ford D60 from a '78
Old March 26th, 2013, 12:37 PM   #4
deerebowtie
Unchained
deerebowtie's Avatar
$7.99 a seal http://www.4wheelparts.com/Drivetrai...FQdU4AodyS8A4g
if the gear oil looks dirty, scrub everything up with diesel until its clean, then re-assemble.
Old March 26th, 2013, 12:39 PM   #5
Complete Off Road
Complete Off Road's Avatar
Its likely just the seals. We have them for about $12 each.
Or if you go for the master kit, I can get that to you for less than $210 delivered.
Andy
Complete Off Road is offline   Reply With Quote
Old March 26th, 2013, 01:16 PM   #6
bigbchevy
missmrgreenagain
bigbchevy's Avatar
J I can get a master kit for $160
H.o.r.e
Old March 26th, 2013, 01:23 PM   #7
knaffie
knaffie's Avatar
What often happens is mud will get past the outer seal and into the inner seal, and will eventually ruin it. You should get some of the better outer seals to prevent it from happening again.
Old March 26th, 2013, 02:00 PM   #8
firehawk
Live Action!
firehawk's Avatar
Much better price
The oil was clean, only been a few trips since the gear swap.
But both D60, front and rear are leaking at all four corners
Old March 26th, 2013, 02:01 PM   #9
firehawk
Live Action!
firehawk's Avatar
Where does the outer go? I would have thought there would be one on the outer end of the housing to prevent all the mud, sand and dirt from getting in the tube. But not on my axle.
Old March 26th, 2013, 02:04 PM   #10
knaffie
knaffie's Avatar
It goes exactly where you would expect it to - on the end of the axle tube. It keeps the tubes from getting all full of mud / sand / dirt / whatever and ruining your inner seals.
Old March 26th, 2013, 02:05 PM   #11
firehawk
Live Action!
firehawk's Avatar
The part of the axle shaft that would seal with this is rusty. Do I need to get it machined? So is the inside of the axle.
Old March 26th, 2013, 02:06 PM   #12
knaffie
knaffie's Avatar
I don't think machined. Wire wheel and sandpaper should do the trick just fine.
Old March 26th, 2013, 02:08 PM   #13
firehawk
Live Action!
firehawk's Avatar
Thanks, I can get it nice a smooth.
Old March 26th, 2013, 02:10 PM   #14
firehawk
Live Action!
firehawk's Avatar
I also need a caliper bracket for the drivers side. It seems to be bent. It barely holds the caliper in place, but then again the little bracket that holds it together on the bottom is tack welded on. Can I get one from the auto parts store?
If figures as I just sand blasted an extra one I had and it turns out it has a L on in.
Turns out the bracket is fine, just the retainer bracket was welded on crooked. I will get a new bolt and bolt it on correctly.
Old March 26th, 2013, 02:10 PM   #15
firehawk
Live Action!
firehawk's Avatar
Guess I will order what I need and run what I have for this weekend.
Old March 26th, 2013, 02:18 PM   #16
1 ton tj on 40's
1 ton tj on 40's's Avatar
that a boy
Old March 26th, 2013, 03:34 PM   #17
firehawk
Live Action!
firehawk's Avatar
Originally Posted by 1 ton tj on 40's View Post
that a boy
She is getting close. One more day.
Page generated in 0.30398 seconds with 74 queries
