5 on 5.5 brake rotors - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 25th, 2013, 03:32 PM   #1
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
Default 5 on 5.5 brake rotors
i am in need of a hat style rotor thats 5 on 5.5 im not much of a ford guru can any one point me in the right direction
Old March 25th, 2013, 03:32 PM   #2
hosejockey4506
Visiting Admin
http://www.autozone.com/autozone/par...1_172979_2708_
this might work
Old March 25th, 2013, 03:42 PM   #3
When I converted my 9" to disc brakes I used late 90's 4wd Dodge front rotors.
Old March 25th, 2013, 03:44 PM   #4
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Some old tech. Prices are from 2007.
http://www.misfitoffroad.com/phpbb/viewtopic.php?t=8056
Originally Posted by Zook94
Ok, so if memory serves correctly, '73-'79 Lincoln Mark V rear rotors are 12 inches, maybe a hair bigger in diameter, and 1 inch thick with a 5 on 5.5. Add to this a pair of 4 piston calipers from an IFS Toyota PU, '86 and up. Suzuki guys run the toy calipers all the time with no problems with pedal feel or height.
Originally Posted by JohnnyJ
2001 Dodge Ram rotors are 12" and in 2002 they went to the 17" rims and 13" rotors.
The only thing that I am seeing is that the big Dodge rotors run a little thin compared to a stock chevy rotor, and even to a ford rotor which many use for 5x5.5 conversions with chevy calipers.
Too thin? I dunno. I'm running chevy K10 calipers with ford f150 rotors in the rear, and they are 0.030" under the K10 rotor discard fresh out of the box but are doing fine. I think that's what Jim is running, too.
The dodge only takes it another 0.080" for the 2003 big rotors, but is about the same as the ford for the 2001 rotors.
From Napa for 2003 Dodge 1500:
Item#: TS 48880073
Price: $32.49
Attributes:
# of Bolts:5 Bolt Circle Diameter:5.5"
Discard Thickness:1.039"
Height:2.655"
Outside Diameter:13.23"
Thickness When New:1.102
Vented / Solid:Vented
From Napa for 2001 Dodge 1500 4x4:
Item#: TS 4886917
Price: $39.99
Attributes:
Discard Thickness:1.118"
Height:2.885"
Outside Diameter:12.11"
Thickness When New:1.18"
And finally a 1987 Chevy K10:
Item#: TS 4885608
Price: $35.49
Attributes:
# of Bolt Holes:6 Bolt Circle Diameter:5.5"
Diameter:11 55/64"
Discard Thickness:1.215"
Height:2.304"
Outside Diameter:11.86"
Thickness When New:1.285"
Well, let's add the standard 1982 F150 4x4:
Item#: TS 4885611
Price: $31.99
Attributes:
# of Bolt Holes:5 # of Bolts:5
Diameter:11 23/32"
Discard Thickness:1.12"
Height:2.704"
Outside Diameter:11.72"
Thickness When New:1.185"
Old March 25th, 2013, 03:45 PM   #5
hosejockey4506
Visiting Admin
thanks guys.
Old March 25th, 2013, 05:35 PM   #6
Bones
Bones's Avatar
misfit tech FTW!
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old March 29th, 2013, 04:10 PM   #7
I was trying to find my post from last year and couldn't the other day.
But found it today
These Brackets
http://www.speedwaymotors.com/1969-1...CKET,3348.html
Napa Part #'s
1975 Chevy 1/2 ton 4wd come with pads
Calipers #142-2022 and #142-2023
Parts Plus #'s
1995 Dodge 1/2 ton 4wd......because these fit over the stock flanges of the shafts with no grinding
Rotors P76447
Brake Hoses #BH36761
Little Spacers from Lowe's....cut to fit inside the rotor where the lug stud slides through to center the rotor over the studs
the spacers are "Hillman" no part number but they measure 1/2 x 5/8 x 1
found them in the little hardware isle in the chest of drawers
If I remember I had to grind the brackets a bit to fit the tubes, but for the price it wasn't a big deal, but that was like 5 yrs ago. I have done ALOT of things since then
Post was from this thread
9" disc brake parts and 44 high steer help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 9th, 2013, 09:17 AM   #8
hosejockey4506
Visiting Admin
1995 dodge half ton rotors are going to need alot of work on the lathe to work with the super duty bearings up front arggg
Old June 9th, 2013, 05:51 PM   #9
hosejockey4506
Visiting Admin
wasted alot of time and money today and ended up back at a 1995 dodge half ton rotor and chevy calipers. the newer dodge rotors at just to big for a 15 inch wheel. and the 1978 ford rotors required me to turn the rear shafts down which i did not want to do due since the axle is final assembled and full of fluid.
Old June 12th, 2013, 04:49 AM   #10
BigWheelBob
The 4 Wheel Drive Shop
BigWheelBob's Avatar
I have started it up, put it in gear at a idle, and sat there with a grinder for a few minutes, it really dont take to long.
BigWheelBob is offline   Reply With Quote
Page generated in 0.34897 seconds with 54 queries
