Lift/Alignment Problems? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 24th, 2013, 11:41 AM   #1
mccart400
Default Lift/Alignment Problems?
I have a 79 chevy half ton, lifted 7 inches, 3 suspension and 4 body, and it looks like its sittin crooked. Like the passenger side is a little lower than the driver side. I was wondering if maybe anyone knew why this was or has had experience with it. Also when its being driven, it looks like its going down the road a little sideways. Would that just be in need of a front end alignment or what?? Please let me know if you guys would. Thank you
mccart400 is offline   Reply With Quote
Old March 24th, 2013, 11:53 AM   #2
wave_crusher
I'll Direc your TV
wave_crusher's Avatar
Check your body mounts, make sure they're all there and not rotted away, as well as the bushings. I know of a few 87- trucks that the body mounts went bye-bye and it was sagging on one side; after a body lift instal.
As for going down the road crooked; i'd go ahead and get it aligned but it's probably that the axle was bushed back on one side
Old March 24th, 2013, 12:01 PM   #3
mccart400
Alright Ill check it out and let you know. thanks.
And how do i fix a pushed back axle if that happens to be the problem?
Thanks again
Old March 24th, 2013, 03:08 PM   #4
Bob502
Bob502's Avatar
What type of lift is it? How long has it been on? Spring could be sagging if it is to old or a chineese lift.
Bob502 is offline   Reply With Quote
Old March 24th, 2013, 03:25 PM   #5
mccart400
Im not sure what lift it is or how long its been on. I just bought the truck 3 weeks ago and i'm just trying to get it ready for silver but I seem to keep stumbling across problems. It looks pretty old tho, the nuts on the u bolts wont budge, even with the impact, the u bolt on the passenger side isnt tight.
Old March 24th, 2013, 04:36 PM   #6
joe_jeep
welfare wheeler
joe_jeep's Avatar
a body lift over 3 inches is booty fab and illegal. body mounts are toast i bet.
Old March 24th, 2013, 05:37 PM   #7
dreezy
Haggard Fab
dreezy's Avatar
Measure the distance between the front and rear tires one both sides. If one side is longer than the other you know you have an issue with the axle alighnment.
Shazam Bitches
Old March 24th, 2013, 09:29 PM   #8
mccart400
I measured earlier and the passenger side was a half inch longer than the driver side. Do you know of a way to fix or correct the axle alignment?
Old March 25th, 2013, 12:00 AM   #9
moparhorse
moparhorse's Avatar
Re-drilling where your center pins go on your rear axle perch
moparhorse is offline   Reply With Quote
Old March 25th, 2013, 01:03 PM   #10
wave_crusher
I'll Direc your TV
that sounds safe
Old March 25th, 2013, 01:11 PM   #11
firehawk
Live Action!
firehawk's Avatar
We need pictures to be sure what it might be. Post as many as you can from far away and close up. Probably an easy fix.
Old March 25th, 2013, 01:14 PM   #12
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
if you're just going to silver lake, then why does it matter?
Sounds like a trail beater that's been beaten.
Old March 25th, 2013, 01:22 PM   #13
firehawk
Live Action!
firehawk's Avatar
That's rude
Old March 25th, 2013, 01:28 PM   #14
kickstand
circling the drain
kickstand's Avatar
If the rear has a lift block it can easily shift and cause dog tracking like you explained.
At the very least get an alignment, check for broken springs in your leaf pack, and it sounds like it wouldn't hurt to get some new u bolts all around.
Old March 25th, 2013, 01:36 PM   #15
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
That's rude
Just speaking the truth. In high school I drove a 79 chevy that had previously lived as a work truck. It dog tracked horribly, as in you could almost read the signs on the door while driving behind me.
Old March 26th, 2013, 02:57 PM   #16
wave_crusher
I'll Direc your TV
First I'd check to make sure nothing broke, such as leaf springs, or spring mounts that kinda thing. And like someone else said make sure the lift blocks (if you have them) didn't shift.
You also need to figure out if it is the rear axle or front axle that is crooked, the most likely is a lift bock. If that's the case; good excuse to get rid of them and get new springs.
Old March 26th, 2013, 09:24 PM   #17
mccart400
Its definitely the rear and I'm pretty sure it has something to do with the lift block on the one side like you guys were saying.
Looks like I'm gunna have to start lookin for some new springs
Old March 27th, 2013, 07:24 AM   #18
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Why not take apart the side that appears shifted and investigate instead of just looking for new springs?
It could be something as simple as a broken centering pin. The new u-bolts would be more expensive than the centering pin.
Old March 27th, 2013, 07:31 AM   #19
BigBird
Duck Shootin' Wheelerer!!
BigBird's Avatar
I changed the axle in my ole truck and when I lowered the truck onto the lift blocks the centering pin missed the hole in the lift block and settled nicely next to it, causing a severe dog track issue. I loosened the u bolts and registered the pin on the block a week later.
Cheap Thrills Off Road
Old March 27th, 2013, 07:05 PM   #20
mccart400
I can't get the nuts to move on the u bolts tho, even with the heating torch. They're locked on good.
Page generated in 0.46495 seconds with 83 queries
