YJ hydro assist. - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 31st, 2013, 11:29 AM   #21
jbeemer
Built not bought!!
jbeemer's Avatar
Originally Posted by XJcoupe View Post
did you mod your pump for more flow?
pump mod link
http://westtexasoffroad.homestead.co...rsteering.html
Mine was slow and resistive before I did this pump mod.
jbeemer is offline   Reply With Quote
Old March 31st, 2013, 11:33 AM   #22
firehawk
Live Action!
firehawk's Avatar
I never modded my pump.
But you ran the GM pump right?
I might try a rebuilt pump or just a different factory one.
Like you said might just be something to get used to. It works but I cannot go fast as it does not respond in a safe way. I could have killed a few trees a couple different times when I was in 3rd gear. Would also like to get a tighter turning radius if possible but it is limited by the ram and box or arm.
Old March 31st, 2013, 11:35 AM   #23
firehawk
Live Action!
firehawk's Avatar
I will probably try it before I swap pumps.
Old April 1st, 2013, 08:43 AM   #24
MiNi Beast
MiNi Beast's Avatar
Your the exception to every thing. Your just special.
Old April 1st, 2013, 08:44 AM   #25
That and he's talking about a completely different power steering pump
Old April 12th, 2013, 11:58 AM   #26
Where did you end up?
Old April 12th, 2013, 12:42 PM   #27
firehawk
Live Action!
firehawk's Avatar
It works but is slow and resistant. I think I will try the pump mod, probably wont happen until next month.
Old April 12th, 2013, 12:47 PM   #28
Have a local parts store that will order stuff in without a restocking fee?
Old April 12th, 2013, 12:58 PM   #29
firehawk
Live Action!
firehawk's Avatar
I dont mind replacing the pump, I don't think it worked that great before the assist but it doesnt whine at all.
Anything worth upgrading to instead of a factory pump or is that sufficient?
I do not plan on spending $400+ for a PSC or Howe.
Old April 12th, 2013, 01:16 PM   #30
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
pump mod link
I did this mod twice and both times led to pump failure. Once was a broken input shaft, the other was a burnt up pump. However this was done to a GM P-pump without hydro assist.
Looking forward to seeing how it works with assist. With you being the guinea pig
Old April 12th, 2013, 01:18 PM   #31
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
krc and other circle track manufactures can build you a pump to your specs for far less. Just have to call around
Old April 12th, 2013, 01:30 PM   #32
Order one of these and see if it fits if you can return them without restock fee. I no longer have " a guy" that will order stuff for me to figure these things out
Looks like this:
Napa, the part number is 811159 for just the pump. 8163159 with the tank.
2002 4.7 V8 Grand Cherokee with hydraulic fan.
Pump info:
http://www.pirate4x4.com/forum/gener...l#post15086750
Reducing the flow back down when not using the fan.
http://www.pirate4x4.com/forum/gener...l#post13309791
Thread for fitting on one end(or get custom hose made, which is my plan)
http://www.pirate4x4.com/forum/gener...e-adapter.html
http://www.anplumbing.com/Adapters/Metric-25.html
AN-10 Earl's 9919FFL - Earl's AN to Metric Thread Adapter Fittings
AN-12 Earl's 9919GFL - Earl's AN to Metric Thread Adapter Fittings
Gear box side is either 16mm o-ring or 18m o-ring, can't remember off top of my head.
An entire thread. Don't mind the people that don't want to get a custom high pressure hose made
http://www.naxja.org/forum/showthrea...=946090&page=9
Only been gathering information so far but this seems to be the only oem TC pump that is built to handle higher flow rates.
Old April 12th, 2013, 02:47 PM   #33
firehawk
Live Action!
firehawk's Avatar
Looks like this:
Pump info:
Now I have to decide if I try a rebuilt factory pump or go this route.
Old April 12th, 2013, 03:08 PM   #34
Get one and see if it fits with the GC reservoir first. Take a picture for me.
Old April 12th, 2013, 04:01 PM   #35
firehawk
Live Action!
firehawk's Avatar
I was just going to get the pump and make a reservoir as I highly doubt that big one will fit.
Probably going to try the pump mod first.
Old April 12th, 2013, 04:04 PM   #36
Looking at pictures of it on a vehicle and how much room the 4.0's have stock, I think it will fit, hence asking for pictures
Old April 12th, 2013, 04:28 PM   #37
1 ton tj on 40's
1 ton tj on 40's's Avatar
you should have payed up an got the tj an not picking that crap setup from some ass hole
Old April 12th, 2013, 06:09 PM   #38
firehawk
Live Action!
firehawk's Avatar
So true
I like the figure it out process too. At least it works, kinda
Better than with the assist, I bought a spare ram too.
Old May 11th, 2013, 05:54 PM   #39
grandcherokee
I am woman,hear me moan!
grandcherokee's Avatar
Send a message via Yahoo to grandcherokee
I put Hydro on my YJ .I really can't wait to go wheeling again...what a difference..
1994 YJ
1993 XJ
1994 XJ
2000 Grand Cherokee
2002 Chevy Silverado
2008 Liberty
grandcherokee is offline   Reply With Quote
Old May 11th, 2013, 05:59 PM   #40
bigbchevy
missmrgreenagain
bigbchevy's Avatar
Full hydro
H.o.r.e
Page generated in 0.54440 seconds with 83 queries
