Rubicon tcase into an 04 LJ - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 23rd, 2013, 04:59 AM   #1
RubiGr8LJ
Mello Yello
RubiGr8LJ's Avatar
Default Rubicon tcase into an 04 LJ
I have an 04 LJ and am planning a rubicon tcase swap. I have been searching around for a write up, no luck finding one that is LJ specific. Wondering if anyone has done it or knows the answers.
I already have a body lift with a flat skid. Currently the skid is dropped 1'' and I took out my budget boost to make up the difference in angle for the stock DS so I could still run it prior to the tcase swap. I know I will need to get a longer rear drive shaft since the rubi tcase has the SYE but I'm wondering about the front DS and any other possible issues? I intend to take out the 1'' drop on skid and be completely flat once new tcase goes in.
From my understanding everything should be a direct bolt in with exception to the drive shafts? I've never had to modify a DS or buy a new one due to another mod changing the distance from tcase to pinion yolk, recommendations on where to go for ds modification or purchase of new and any advice would be appreciated.
RubiGr8LJ is offline   Reply With Quote
Old March 31st, 2013, 11:40 AM   #2
Tie Dyed
O.G.
Tie Dyed's Avatar
Send a message via AIM to Tie Dyed
As long as the trans from what you took it from, and what you are putting it into are the same, I see no issues. Front drive shaft should be a bolt in. IIRC, the front yoke did not change.
2000 XJ with a 3 inch body lift
Tie Dyed is offline   Reply With Quote
Old March 31st, 2013, 11:54 AM   #3
Deuce
Dirty
Deuce's Avatar
Shawn put a Rubi T case in his LJ, so he would be someone to ask.
Deuce is offline   Reply With Quote
Old April 1st, 2013, 07:39 PM   #4
toolmantim
Go lil yellow Roobicon...
toolmantim's Avatar
The flatness to frame/clearance of your skid could be an issue depending on your trans. Getting the T-case up enough before hitting the tub could be a issue if your running the OD auto trans and trying to keep that trans pan above the frame rail bottom.
I'm assuming your running a 1BL?? You might save your self some time and start fitting that T-case and it's connections, breathers, and linkage on your tub while fitting your skid before you get rear drive shaft. Your going to need a double cardon shaft for the rear if your running a flat skid anyway so you might as well just see where your DS angle is at that WB and get it once if ya can, might even get super lucky and get that BB back on without changing your rear pinion angle and just getting a rear shaft...but I doubt it.
FWIW you should be able to move that T-case up from it's factory/stock position (with a BL) a good 1.5 inches and use a factory Rubi/LJ DS without a problem.
your front DS should be fine.
I'm compensating for my manhood.
Northwest Ohio Crawlers
toolmantim is offline   Reply With Quote
Old April 1st, 2013, 07:59 PM   #5
RubiGr8LJ
Mello Yello
RubiGr8LJ's Avatar
I started in on this saturday. Took off the flat skid and supported everything to start unbolting the tcase. Once I had it out the Rubi tcase went right in. I picked up a tcase mount today since the old one had a bolt sheared off. As of now the tcase is bolted to trans and waiting to bolt/plug everything back in. I didn't measure the body lift, but I would guess it to be more than 1'' and was installed when I bought the LJ. From what I see at this point everything should bolt right in and the skid up tight to the frame. I was reading up on junk yard upgrades and found a guy who bought a front DS from a junk yard explorer, had it shortened/balanced and used it for his rear, ran him $130 bucks. I'm thinking of going that route myself. As for front DS, I'll wait and see what happens once all is in right and tight.
Old April 1st, 2013, 08:04 PM   #6
RubiGr8LJ
Mello Yello
RubiGr8LJ's Avatar
I'm curious if I will be able to use front, it just seems like a lot of lift on the tcase for it to reach the same. If so I'll be happy.
Old April 2nd, 2013, 10:20 AM   #7
shawn
Resident HVAC/R Jambi
shawn's Avatar
I don't have a body lift, but I do have a Full Traction LA kit. It has a very flat skid plate, and I had to do some clearancing with a mallet, towards the drivers side floor.
The only other thing you need to do is change the shifter linkage. Or, do what I did and modify what you have. I bent mine, and then gusseted it.
Old April 2nd, 2013, 07:14 PM   #8
RubiGr8LJ
Mello Yello
RubiGr8LJ's Avatar
Thanks for the info
Old April 3rd, 2013, 06:36 AM   #9
Eric99tj
Just bump it....
Eric99tj's Avatar
Have you tried mounting up the front driveshaft yet? I thought that the 231 has a 1310 front output and the Rubi T-case has a 1330. I know that you can get a yoke to make the rubi 1310. Just wondering.
Southern Michigan Rockcrawlers
Eric99tj is offline   Reply With Quote
Old April 3rd, 2013, 10:50 PM   #10
RubiGr8LJ
Mello Yello
RubiGr8LJ's Avatar
Not yet. I may get to it tomorrow morning otherwise it won't be till monday morning. I would have today but I had to get myself 20 chickens and a coop from a coworker. Can't lose with free laying hens and a coop.
Old April 8th, 2013, 08:02 PM   #11
RubiGr8LJ
Mello Yello
RubiGr8LJ's Avatar
Everything looks good so far, the wire harness had one connection that doesn't plug together I think its for the dash light. Didn't check. Hoping to call around and find a front shaft from junk yard to use for rear.
Old April 8th, 2013, 08:43 PM   #12
shawn
shawn's Avatar
I still haven't hooked up my 4wd light. And the speedo plug will plug in, but you can't change a speedo gear for calibration.
Old April 10th, 2013, 08:46 PM   #13
RubiGr8LJ
Mello Yello
RubiGr8LJ's Avatar
The front output on the rubi tcase works with the stock drive shaft. It's a 1310. However the rear is 1330.
Old April 11th, 2013, 06:31 AM   #14
Eric99tj
Just bump it....
Eric99tj's Avatar
Interesting... What year vehicle did the Rubi tcase come out of?
Old April 11th, 2013, 08:15 AM   #15
shawn
shawn's Avatar
The drive shaft lentghs should be the same. I put a 1310 yoke on the front and used my factory regular front drive shaft. The rear I ordered one with a 1310 flange adapter. So all my u-joints were still 1310.
Old April 11th, 2013, 07:40 PM   #16
RubiGr8LJ
Mello Yello
RubiGr8LJ's Avatar
2005 rubicon. Unless its the ubolt style yoke and not the strap, i just put the front ds up to it to check the fit, never bolted it in. That comes in the morning after I pick up my new yoke for rear axle.
Old April 11th, 2013, 07:43 PM   #17
RubiGr8LJ
Mello Yello
RubiGr8LJ's Avatar
I'm upgrading the rear axle yoke to 1330 so my rear DS is all 1330 ujoints. I didn't think the front output on the tcase would be 1310 but the seller may have put it on, he said he was looking up some part numbers to make things easier for my install.
Old April 12th, 2013, 07:38 AM   #18
idiot magnet
idiot magnet's Avatar
When I did this swap I picked up a LJ Tom Woods driveshaft with the adaptor that bolts to the Rubi balancer. I would suggest getting the Novak cable shifter to prevent binding. I will be installing mine as soon as I get my flat skid finished. For now I cut approx 1" out of my shifter linkage, welded it back together and did some testing to see how it would shift. A bit of trial and error and it shifts fantastic.
There is a good chance you have the 1 1/4" which seems to be the norm with a 1" MML.
I also cut my front driveshaft boot off to make sure it would extend as far as it needed to without causing issues.
Once you get it installed and you test out the 4:1 you will be amazed at the difference.
This was one of the best mods I've done to my LJ and it was cheap, but I got lucky with my parts and found some killer deals.
Look at the Tatton driveshaft for a bit more money you will have a much more stout driveshaft.
Good luck with the swap.
idiot magnet is offline   Reply With Quote
Old April 12th, 2013, 11:22 AM   #19
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
I wouldn't say that. This Tatton failed right at where the rear yoke was welded on. No scrapes, dents or anything of the sort on the drive shaft. After looking at it, it was easy to see that the weld was cold (IE no heat marks on the tube). Also it was ground down to being almost smooth, which goes along with shitty welds in most cases.
If I were to recommend a drive shaft it would from http://oliversdriveshaft.com/ quick turn around, cheap shipping, and more than fair prices. Not to mention Dave was able to build and balance a 2.5"x.250" DOM rear drive shaft for me. Runs true and smooth on the high way and is proof!
Old April 12th, 2013, 05:32 PM   #20
idiot magnet
That sucks about the Tatton driveshaft. My buddy Joe runs one without any problems. Hopefully they have better welds now.
Good to know about another source for driveshafts. I'm very happy with my TW driveshaft, but I got a great deal on it when the guy went a different direction with his build.
Page generated in 0.55713 seconds with 84 queries
