im haveing engine trouble - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 22nd, 2013, 06:09 PM   #1
kowboy
i hit the hole too fast
kowboy's Avatar
Default im haveing engine trouble
My 1999 V6 silverado stalled on me today. My buddy towed it home for me, looked under the hood. I have spark and fuel and the coil works. Its cranking over but won't run, I'm stumped, any suggestions
kowboy is offline   Reply With Quote
Old March 22nd, 2013, 06:52 PM   #2
jbsjunk
Little Member
jbsjunk's Avatar
I've had several that burned thru the rotor. Changed that and all was well.
Old March 22nd, 2013, 06:54 PM   #3
Toyfish
Toyfish's Avatar
Start with cap and rotor
Sent from my DROID X2 using Tapatalk 2
Old March 22nd, 2013, 08:51 PM   #4
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
i sent you a pm.
Old March 22nd, 2013, 09:07 PM   #5
Wehan
Wehan's Avatar
If it cranks, has spark and air then start looking to fuel. Pump, relay ect.. If you have fuel like you said is the pressure there to supply enough to run/start?
Just for Schweeb
Wehan is offline   Reply With Quote
Old March 25th, 2013, 12:04 AM   #6
moparhorse
moparhorse's Avatar
What color spark is at the plug? If its blue and not yellow, then you would want to check your fuel pressure. Does the exhaust smell fuel when you crank it over and have you tried holding it at half throttle or more while trying to crank it?
moparhorse is offline   Reply With Quote
Old March 25th, 2013, 02:16 AM   #7
rammanriley
rammanriley's Avatar
What's the fuel pressure numbers
96 Ram 1500 ECSB 5.9l v8 4x4 On 35's
13 Dart Aero (turbo go fast)
rammanriley is offline   Reply With Quote
Page generated in 0.24299 seconds with 44 queries
