Comp Bog April 13 Gladwin County Fairgrounds - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > General 4x4 Stuff > Trail Rides & 4x4 Events
Old March 22nd, 2013, 11:33 AM   #1
Bad Influence
Default Comp Bog April 13 Gladwin County Fairgrounds
Gladwin Comp Bog has been postponed until Saturday April 20.
We were hit with an ice storm last night. Many with no power or phone.
Hopefully by the 20th it will be warmer too
Name:	gladwin bogs_n.jpg
Last edited by Bad Influence; April 12th, 2013 at 04:52 PM. Reason: A week of rain and then an ice storm
Bad Influence is offline   Reply With Quote
Old March 24th, 2013, 09:55 AM   #2
ronprice
ronprice's Avatar
Will be there to watch. Something to do close by for me.
ronprice is offline   Reply With Quote
Old April 9th, 2013, 07:12 AM   #3
unleashed
unleashed's Avatar
This is coming up......who's going?? Would like to see a good turn out from GL4X4
unleashed is offline   Reply With Quote
Old April 12th, 2013, 04:54 PM   #4
Bad Influence
Not until the 20th Kathy, cuz of the ice storm.
Old April 13th, 2013, 09:34 AM   #5
unleashed
unleashed's Avatar
OK then.....GL4X4 people...that gives you another whole week to get ready. This event had a pretty good turn out last year for what I believe was their first one. If you can't run it, you might want to just spectate and check it out
Old April 13th, 2013, 05:03 PM   #6
moparhorse
moparhorse's Avatar
To bad there not having the drag again. The 46 is itchin to run
moparhorse is offline   Reply With Quote
Old April 15th, 2013, 12:28 PM   #7
Bad Influence
It should be good, pit has to be wet with all the rain we have had. Their calling for more this week too.
Old April 15th, 2013, 12:37 PM   #8
mudviper
getting dirty
mudviper's Avatar
Send a message via Yahoo to mudviper
Is there a tech check in for street class? Helmets required? Anything else drivers should know?
Thanks
mudviper is offline   Reply With Quote
Old April 16th, 2013, 08:46 PM   #9
mudford
mudford's Avatar
I'll be there with my Bronco.
Mudviper- I would definitely bring your helmet. I am wondering about the street class also. I have a license plate on it, so I must be in the street class, right?
mudford is offline   Reply With Quote
Old April 17th, 2013, 12:07 PM   #10
Bad Influence
A helmet, fire extinguisher and a 3/4 screw clevis in place of your trailer hitch ball.
Yes there will be a tech inspection on all vehicles. Just got a call from one of the guys in charge of the pit. He's looking for someone to try it out before Saturday. Any takers?
If so call Terry 989-302-0100. I would but found a wheel bearing that needs attention.
Old April 17th, 2013, 12:12 PM   #11
Bad Influence
You are allowed 2 mod.s to your engine and can still be in the street class.
Like cam and carb, or headers and ignition and so on. 3 or more your in the mod class.
Lift kit doesn't count as long as it is not 4 linked.
Old April 17th, 2013, 12:16 PM   #12
Bad Influence
Thanks
Question answered further up this page, trying to clear up any confusion.
THANKS
Old April 17th, 2013, 12:18 PM   #13
Bad Influence
Calling for another 3 inches of rain by Saturday. This should be an intresting bog. They can pump water out of the hole if need be.
Old April 17th, 2013, 12:22 PM   #14
mudviper
getting dirty
mudviper's Avatar
So you can have cut tires and still be in street class from what I am understanding?
Old April 19th, 2013, 11:29 AM   #15
Bad Influence
Street class must have DOT approved tires. I think cut tires puts you in the open class. They will tell you for sure at tech inspection
Old April 19th, 2013, 11:37 AM   #16
Bad Influence
Going to be a good hole in Gladwin. Went to the fairgrounds yesterday a took a look.
For any questions about mod.s or cut tires, please click on the flyer on the top of this post, THANK YOU.
Old May 22nd, 2013, 01:46 PM   #17
mudford
mudford's Avatar
Hey Bad Influence, when is the next comp bog in Gladwin?
Old May 23rd, 2013, 11:32 AM   #18
Bad Influence
Default Next Gladwin Comp Bog
The next Comp. Bog in Gladwin is going to be a part of the county fair.
According to the Gladwin County Fair Schedule, thats on-line right now,
it is going to be on Friday July 26th at 7pm. Going to run it under the lights this time.
Keep ya posted on what time tech. inspection is.
Looks like this one is going to be a lot better than last time.
The next time we have a play bog, I'll let you know. Do a little test and tune.
Page generated in 0.37325 seconds with 78 queries
