Front pinion bearing need help $$ - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > General 4x4 Stuff > Meets, Greets, and Wrenching
Old March 22nd, 2013, 11:11 AM   #1
Dans TJ
Dans TJ's Avatar
Default Front pinion bearing need help $$
Never mind I ended up doing it was not hard at all
Last edited by Dans TJ; April 24th, 2013 at 07:53 PM. Reason: Want to delete thread but can't figure out how
Dans TJ is offline   Reply With Quote
Old March 22nd, 2013, 11:33 AM   #2
luvitmyjeep
broken
luvitmyjeep's Avatar
make sure you replace all you seals! you will not want to take it all apart again, youll probaly have to order them and will probaly take a few days, pluss youll probally have to make a tool for it. its not hard just slow and boaring.
luvitmyjeep is offline   Reply With Quote
Old March 22nd, 2013, 02:09 PM   #3
Toyfish
Toyfish's Avatar
Its pretty easy i can help u throw ot together on a weekend
Sent from my DROID X2 using Tapatalk 2
Old March 22nd, 2013, 10:39 PM   #4
pigfat
GONE COMMANDO
pigfat's Avatar
If its the outer pinion bearing you might be able to just pull the seal and wiggle the bearing out and put a new one in. I know itll be the old race but short of rebuilding the whole axle that could be all you need.
pigfat is offline   Reply With Quote
Old April 4th, 2013, 03:43 PM   #5
Toyfish
Toyfish's Avatar
u get your parts yet?
Page generated in 0.12715 seconds with 38 queries
