I wanna paint my cage.... - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 20th, 2013, 12:19 PM   #1
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Default I wanna paint my cage....
I wanna paint my cage with some affordable paint, that can be touched up easy, what are my options?
I am currently using rustolium rattle can, but it rubs off easy on trees and doesn't hold up in the salty weather.
Old March 20th, 2013, 12:28 PM   #2
firehawk
Live Action!
firehawk's Avatar
I would use Epoxy or Imron if you want durable, the Epoxy usually needs to be topcoated. I like to use epoxy and then top coat with something that can be touched up with a rattle can. Satin black is one of my favorite finish's
All paint will come off when rubbing it against something but Imron is some strong shit and you have to use the proper PPE when using it.
Old March 20th, 2013, 01:50 PM   #3
Don't rub it on trees.
Krylon seems to work OK. I'm a big fan of rattle can paint for a trail rig. Although I don't repaint my stuff as frequently as Tab.
Old March 20th, 2013, 01:57 PM   #4
buttercr125
I work out
buttercr125's Avatar
Home depot $1 cans of rattle can paint! They have very limited colors but they are cheap and seem to work well.
Old March 20th, 2013, 02:02 PM   #5
Toyfish
Toyfish's Avatar
U can get a gallon of implement paint a tsc for $30 and it holds up pretty good
Sent from my DROID X2 using Tapatalk 2
Old March 20th, 2013, 04:51 PM   #6
joe_jeep
welfare wheeler
joe_jeep's Avatar
rustoleum is too soft. buy the cheapest paint you can, or go to tsc and get oil based enamel. takes for ever to dry, but its tough and keeps the rust away.
Old March 20th, 2013, 04:56 PM   #7
Marion3
Marion3's Avatar
I'd por-15 the cage then rattle can it.
Marion3 is offline   Reply With Quote
Old March 20th, 2013, 07:03 PM   #8
bluminade
Bluminade Has Arrived
bluminade's Avatar
duplicolor wheel paint
bluminade is offline   Reply With Quote
Old March 20th, 2013, 07:20 PM   #9
Grassman
2jz specialist
Grassman's Avatar
Elmers Glue And Glitter mixed
Old March 20th, 2013, 07:29 PM   #10
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Thanks for the replys
I don't want just a cheap paint, I want it to look nice. I was gonna spray an acrylic enamel, but touch ups will not be easy since the cage will be getting scrapped up. I did the rustolium thing all last year, its fine but rubs off easy and now with the winter, everything rusted up and its pissing me off.
So wheel paint, its that pretty durable? Epoxy spray paint any good? Or just spray it with a good enamel?
Hmmm
No glitter on this one....
Old March 20th, 2013, 07:55 PM   #11
Junkyard
Junkyard's Avatar
X2 on Tsc farm and implement paint.... Painted my sand rail with it and it held up really well.
Junkyard is offline   Reply With Quote
Old March 20th, 2013, 08:10 PM   #12
drogers
drogers's Avatar
this with the hardener thay sell . it dry pretty quick with the hardener
drogers is offline   Reply With Quote
Old March 20th, 2013, 08:27 PM   #13
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
I've used it before, guess I'll go look at what colors they have, thinking of doing a different color than black.
Old March 20th, 2013, 08:44 PM   #14
Leopard
Old March 20th, 2013, 08:53 PM   #15
MUDDERofaJEEPER
squirrel bait
MUDDERofaJEEPER's Avatar
I'm going to uses vht roll bar paint, not sure if you wanted a different color than gloss black or satin.
http://www.oreillyauto.com/site/c/de...0484&ppt=C0171
MUDDERofaJEEPER is offline   Reply With Quote
Old March 20th, 2013, 09:03 PM   #16
curbdog17
Mini Van
curbdog17's Avatar
win
Old March 20th, 2013, 09:28 PM   #17
HPandThrottle
have fun or die trying
HPandThrottle's Avatar
sherwin williams sells industrial alkyd enamels that are very durable and touch up easily can be brushed or thinned and sprayed both with good results was about 40 a gallon
HPandThrottle is offline   Reply With Quote
Old March 21st, 2013, 02:40 AM   #18
muddinman56
blood,sweat and beers
muddinman56's Avatar
Kyle do not get wheel paint it's just as bad as rustoluim I had wagon wheels with wheel paint on them and they rusted just as fast IMO both shitty.
Did the oil base tsc paint on them and that lasted but took for ever to dry
I would go with the tsc implement paint we put in on my buddy's bump and run car
But we did 2 coats brush and 2 coats with the spray gun and some hardner and it's still on there pretty well.
Old March 21st, 2013, 11:15 AM   #19
Bones
Bones's Avatar
your issue isn't tha piant, its the primer and prep. You need to clean the tube 100% of all the oils. Do a few rub downs with acetone, etc to clean the tube and then get a good metal etching primer on the tube before any paint. Once the primer is on, any of the higher quality rustoleum spray paint will look good for years.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old March 21st, 2013, 05:07 PM   #20
joe_jeep
welfare wheeler
joe_jeep's Avatar
the dupli color caliper paint gets very hard when its dry! very durable. try a small spot and see how you like it.
Page generated in 0.41663 seconds with 83 queries
