Electric power washers. - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 17th, 2013, 05:35 PM   #21
Jiveturkey3
Jiveturkey3's Avatar
Originally Posted by BlooMule View Post
I would like to see the math proving that 2GPM into a pressure washer equals 2.5GPM out.
If you only have two gallons in a minute coming in, the washer does not add water, only increases pressure.
I have never had an issue with running one dry. Not saying it can't happen but wouldn't that require no water in? Say I have 1.5 gpm from my well, ignoring the variable of plumbing am hose for easy math. The pressure washer is rated at 2.5 gpm. Wouldn't it pump 1.5 gpm if that was what was supplied via the hose? Must they run at full capacity at all times in order to work at all?
Jiveturkey3 is offline   Reply With Quote
Old March 17th, 2013, 05:49 PM   #22
MonkeyBiz
Master Cocksman
MonkeyBiz's Avatar
What well/city water hook up size do you guys have that you're worried about 2GPM? With shower, washer and dishwasher running I still get about 7GPM from the spicket on the furthest end of my water lines...
Old March 17th, 2013, 05:50 PM   #23
MonkeyBiz
Master Cocksman
MonkeyBiz's Avatar
The only guess I have is that in theory, the pressure washer creates a vacuum of sorts.
Old March 17th, 2013, 05:56 PM   #24
Jiveturkey3
I agree. When are well was tested before we bought the house it was around 15 gpm iirc.
Old March 17th, 2013, 05:59 PM   #25
Ebs
I've been rockin' a cheap electric one for a quite a few years, no issues, works just fine. I did salvage a better wand and rubber hose from a nicer gas powered washer.
Old March 17th, 2013, 06:00 PM   #26
BlooMule
Old School
BlooMule's Avatar
I wish I had that.
2 years ago I timed how long it took to fill a 5 gallon bucket. With nothing else using water, I could fill a bucket in just under a minute.
Turn on the shower, it took a minute and a half.
To fill a 5 gallon bucket in my shower takes 3 minutes.
The line coming in to my meter is 1/2" and if it's anything like the water lines that were going to my utility sink, it's choked down to 1/4" inside.
I was trying to wash down the lawnmower one time when my wife started a load of wash. The pressure washer pump started cavitating.
I hate this house.
-rw-rw-rw
Old March 17th, 2013, 06:05 PM   #27
Suta99
Suta99's Avatar
My point is that the pump will suck the water at a greater volume than capable from your free flowing tap.
Old March 17th, 2013, 06:11 PM   #28
MonkeyBiz
Master Cocksman
MonkeyBiz's Avatar
Told ya so.
So Suta, with that theory, you could stick a garden hose in a lake, and attach it to a pressure washer and it should flow just fine, right?
Old March 17th, 2013, 06:21 PM   #29
Suta99
Suta99's Avatar
I'm not saying that it will actually pump the required 2.5 gpm but should alleviate some resistance.
Old March 17th, 2013, 07:01 PM   #30
Jiveturkey3
Told ya so.
Very true. I have used one attached to a 15,000 poly tank.
Old March 17th, 2013, 07:27 PM   #31
MonkeyBiz
Master Cocksman
MonkeyBiz's Avatar
Do you suck it out of the tank or does it gravity feed?
Old March 17th, 2013, 07:41 PM   #32
Jiveturkey3
I don't believe in gravity. So obviously it is suction.
Page generated in 0.31814 seconds with 58 queries
