Electric power washers. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 15th, 2013, 02:17 PM   #1
Jiveturkey3
Jiveturkey3's Avatar
Default Electric power washers.
I just started to clean the rzr after my first ride. I come to the conclusion I need a pressure washer. I have very few uses for one and don't really want to spend money on a "nice" one. Basicly washing the rzr, driveway, and maybe the house once a year. Electric seems to beach cheaper am I don't need high psi numbers. What are the thoughts on these? Doe anyone have one that works well they would recommend?
Jiveturkey3 is online now   Reply With Quote
Old March 15th, 2013, 02:33 PM   #2
Big_T_Roose
Big_T_Roose's Avatar
We had one and it did on decent job, but you had to pull around the hose and the power cord. So when you are not washing by a power outlet you have to get out the long extension cord.
I ended up buying a cheaper gas powered one to wash my quad, trailer, truck, and what ever else I needed to wash. I would recomend a gas powered one over the electric. To compare my cheap one to a good gas powered one, i would need to use a narrow tip (15 deg I think) compared to the wider (30 deg tip) to get the same results.
Big_T_Roose is offline   Reply With Quote
Old March 15th, 2013, 03:19 PM   #3
cmays03
BUILD BY ME NOT BOUGHT!
i got one from tsc it works great to wash my rig after a day of mudding. heres a link to it.
http://www.tractorsupply.com/en/stor...ressure-washer
cmays03 is offline   Reply With Quote
Old March 15th, 2013, 04:17 PM   #4
joe_jeep
welfare wheeler
joe_jeep's Avatar
gas power or dont bother.
Old March 15th, 2013, 04:20 PM   #5
montecarlo33
The Violator
montecarlo33's Avatar
I thought the same, but I use my electric smaller one alot now that i got both. Works great for the quick smaller jobs and is nice and quiet.
Old March 15th, 2013, 04:36 PM   #6
Wehan
Wehan's Avatar
Got a huskey one from home Depot for $100. Does a good job for what I need it fore.
Just for Schweeb
Wehan is offline   Reply With Quote
Old March 15th, 2013, 04:48 PM   #7
skife
skife's Avatar
Find a used kracher
Old March 15th, 2013, 04:56 PM   #8
Easy_E
Web Wheeler !
Easy_E's Avatar
Originally Posted by skife View Post
Find a used kracher
Thats what I have . Works way better for household cleaning. Low noise , no gas and when winter comes put it in the basement.
Easy_E is offline   Reply With Quote
Old March 15th, 2013, 05:10 PM   #9
Jiveturkey3
Sounds like just what I need. Where can I find a kracher? That's a brand I assume? What makes them better than others? As far as gas vs electric I just don't see the need when I will only be doing small jobs that will no require high psi. I have many outlets outside and plenty of gfi cords if needed.
Old March 15th, 2013, 06:11 PM   #10
toolmantim
Go lil yellow Roobicon...
toolmantim's Avatar
My father-in-law pulled a coleman electric washer out of his neighbors garbage in 2005 and gave it to me, said it did not turn on. I replaced a wire and repaired a simple on/off switch.
It's hanging in my garage on the wall and I have washed the fawk out my Jeep so many times I can't tell ya.
It's just enough pressure to get all but the large clay/mud clumps packed into deep pockets...but not so much that I'm penetrating rubber seals on electrical plugs in the engine compartment. A 10 year old kid can wash your RZR from set-up to finish and not harm a damn thing.
gas powered is what I use to clean my brick house, and I borrow one.
Check out flea markets,garage sales whatever and chances are you can find a used electric REAL cheap that will last quite a while and not take up much space and zero gasoline.
I'm compensating for my manhood.
Northwest Ohio Crawlers
toolmantim is offline   Reply With Quote
Old March 15th, 2013, 06:21 PM   #11
Its a brand, and its 'Karcher'.
Old March 15th, 2013, 06:38 PM   #12
hotstuff
water=electricity-water-electricity- don't go together
hotstuff is offline   Reply With Quote
Old March 16th, 2013, 06:22 PM   #13
jeepfreak81
81 inches of fun
jeepfreak81's Avatar
Electric fail after only a few years, and on top of that the only way you get any power is on a jet spray (not fan)
Check your local pawn shop for a gas one. I got my last one at a pawn shop inventory reduction auction for $60
Right after I bought it I went to my garage and cleaned the garage, I then found one I bought off of here for $15 that I was told didn't work (bad pump). It worked great after fixing the leaky fitting - cost $3
Old March 16th, 2013, 07:06 PM   #14
BlooMule
Old School
BlooMule's Avatar
I have had a Karcher that I got from Big Lots (a Refurb unit at that) and it's about 20 years old. Works fine, I can even degrease engines with it if I let the chemical cleaner soak in for an hour. It takes longer on heavy jobs like that, but it's fine for mud, and more convenient than running the Big Red 3 wheeler down to the coin op car wash.
If you can hook it up to the drain on your water heater it works even better.
-rw-rw-rw
Old March 16th, 2013, 09:39 PM   #15
Suta99
Suta99's Avatar
I have an old homemade electric power washer that has a 5hp 220v motor and makes tons of pressure and flow. I have it hard mounted with a 100ft hose. Amazing
Old March 17th, 2013, 09:53 AM   #16
Jiveturkey3
I have looked around an the small karchers I find are like 1.4 gpm. I think to be at all effective I need more? 2000 psi at 1.4 gpm is the best I find. Untill you get up to big stationary units.
Old March 17th, 2013, 10:00 AM   #17
BlooMule
Old School
BlooMule's Avatar
Just remember, your water supply has to be higher than the GPM of the washer..... if the garden hose only supplys 2 GPM, your washer can't supply 3GPM and will run dry.
(My water pressure and flow is terrible- even my old electric Karcher will run dry if I have the lawn sprinkler running at the same time)
-rw-rw-rw
Old March 17th, 2013, 10:48 AM   #18
Suta99
Suta99's Avatar
This is true to a certain point but if the flow of hose is 2 gpm adding a pressure washer will effectively increase that flow. Maybe not a lot but you could probably get 2.5 gpm output out of the washer. Most people though shouldn't have to worry since a house with a 5/8" water meter and decent pressure should easily be running 5-10 gpm. If you have a 3/4" meter or bigger it could be a lot more. You need a big pressure washer to exceed those numbers. This is dependant on how your plumbing is run also. Running it from a tap closest to the meter and as wide and as short of a hose as possible is also a plus.
Old March 17th, 2013, 11:57 AM   #19
Sandals
Fucking Zen as Shit
Sandals's Avatar
i was given an electric dirt devil one as a gift, was skeptical, but it works quite well, cleaned my deck and concrete without issue.
Old March 17th, 2013, 04:47 PM   #20
BlooMule
Old School
BlooMule's Avatar
I would like to see the math proving that 2GPM into a pressure washer equals 2.5GPM out.
If you only have two gallons in a minute coming in, the washer does not add water, only increases pressure.
-rw-rw-rw
Page generated in 0.41895 seconds with 82 queries
