pipe/tube notcher what is good? - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 4th, 2013, 02:02 PM   #21
I have done the chop saw method, and I have a harbor freight notcher. If the notcher fits the angle that I want, and the piece of tube, I prefer use that, compared to the chop saw.
THe only issue I have had with mine, is out of the box, it was not hitting perfectly into the center of the tube. (the center point of the clamp was a little off, compared to the centerline of the drill bit). I have one cheap HF drill press that usually I keep the notcher bolted into at all times with a 1-5/8 or 1-3/4 hole saw in at all times as a semi-dedicated notcher. Makes it a lot more convenient if its already set up. I use my mill for drilling 99% of the time anyway.
Old April 10th, 2013, 12:27 PM   #22
CHEROKEEMUDMAN01
mellow yellow
CHEROKEEMUDMAN01's Avatar
1st me and a buddy built with the new notcher and jd2 bender. should have rest of cage done this sat.
CHEROKEEMUDMAN01 is offline   Reply With Quote
Old April 11th, 2013, 01:09 PM   #23
idiot magnet
idiot magnet's Avatar
Here is a great site where you can print out a paper template.
You can adjust the tubing diameter, thickness and angle.
http://www.metalgeek.com/static/cope.pcgi
idiot magnet is offline   Reply With Quote
Page generated in 0.31938 seconds with 33 queries
