pipe/tube notcher what is good? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 14th, 2013, 06:50 PM   #1
CHEROKEEMUDMAN01
mellow yellow
CHEROKEEMUDMAN01's Avatar
Default pipe/tube notcher what is good?
got a couple cages to do coming up and me and a friend are thinking of buying a pipe/tube notcher. just dont know what is any good since i cant find any reviews.
thinking of this woodward fab unit WFN6. http://www.woodwardfab.com/woodward_...ube_bender.htm
anyone have this and is it any good?
i know harbor freight makes one also but i havent had much luck with there tools cause u get what u pay for.
anyone know of a better notcher for the money like under $300
CHEROKEEMUDMAN01 is offline   Reply With Quote
Old March 14th, 2013, 06:54 PM   #2
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
I have the JD2 TN-100. Works great. Only thing I don't like is that you can't put a notch in a bend, you have to be a couple inches away.
Old March 14th, 2013, 06:58 PM   #3
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
Tubing notcher - Great Lakes 4x4. The largest offroad forum in the Midwest
i got a tn100 used and it has works great but i will be buying a notchmaster. both are made by jd2
Old March 14th, 2013, 07:13 PM   #4
CHEROKEEMUDMAN01
mellow yellow
thanks guys ill go with the notchmaster. i did a search on this site also and didnt show up. wierd sorry to be the guy to the same thing. but thanks for link and info glad i asked
Old March 14th, 2013, 07:17 PM   #5
bigbchevy
missmrgreenagain
bigbchevy's Avatar
Woodward fab notcher. There office is at 23&59 in Hartland
H.o.r.e
Old March 14th, 2013, 07:33 PM   #6
I use the harbor frieght, it needs a little modification out of the box, but for the price it works.
That $80 one in your link looks identical to the HF unit.
Old April 3rd, 2013, 08:26 AM   #7
Bones
Bones's Avatar
I'm a cheap ass, so I use math and a chop saw that can cut up to about 60 degrees.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old April 3rd, 2013, 08:29 AM   #8
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Do you have the woodward fab version?
Old April 3rd, 2013, 08:32 AM   #9
CHEROKEEMUDMAN01
mellow yellow
i ended up buying the jd squared notcher cause everyone on here seemed to like it best. havent used it yet but it very hd built.
Old April 3rd, 2013, 11:13 AM   #10
Blue XJ
The Green Machine
Blue XJ's Avatar
Send a message via AIM to Blue XJ
x2 I use my angle grinder with a cutoff wheel to put a V notch in it. Then a flap disc to round it out, works great. Takes about 3-4 minutes per notch.
I have a link on my other computer that you enter the tube diameter and the angle of the intersection and it prints off a template. Tape it on the tube and grind to the line on the template and its a perfect fit. I printed off all the common angles and keep them on hand in the garage.
Blue XJ is offline   Reply With Quote
Old April 3rd, 2013, 11:18 AM   #11
bigbchevy
missmrgreenagain
bigbchevy's Avatar
Yes and its badass . I got a display from a show for 100 off
H.o.r.e
Old April 3rd, 2013, 12:05 PM   #12
Bones
Bones's Avatar
I can almost any joint with a max of 6 cuts with a chop saw and very limited grinding.
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old April 3rd, 2013, 12:08 PM   #13
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
damn you. that is a good deal.
if you only do a tube here or there I can see going this route. But I can't imagine doing a cage without one. Too much wasted time. Heck, I hate how long it takes to take an extra 1/4" off a notch, let alone have to redo 6 cuts and grinding every time.
Old April 3rd, 2013, 12:09 PM   #14
I do this ^
Old April 3rd, 2013, 12:11 PM   #15
Bones
Bones's Avatar
how long dies it take you to do 6 cuts on a chop saw? I bet it is faster than you think... and you only have to change the angle of the chop 3 times. I will post pictures of my joints tonight...
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old April 4th, 2013, 07:28 AM   #16
CHEROKEEMUDMAN01
mellow yellow
i use to do the v notch and then use grinder to make a nice round tube end but it does take a couple min per notch. i have done 3 cages in last year and several bumpers and rock sliders. for the price of the notcher and the fact its build nice and will prob last a lifetime i cant see going back to using grinder to do it ever again.
Old April 4th, 2013, 07:31 AM   #17
firehawk
Live Action!
firehawk's Avatar
Roll em tight.
Old April 4th, 2013, 07:46 AM   #18
jaysusr
jaysusr's Avatar
Google pipemaster. After you get past the surfing shit, its a scribing tool. I haven't used one, but id try it out.
Old April 4th, 2013, 09:20 AM   #19
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
A friend has the 1.75 tube Pipemaster that I borrowed while we did the last rebuild on the TJ. It is helpful for some oddball notches, but in building the entire jeep I think we used it maybe 5 times. As the angle gets steeper I found it to become less accurate; which was generally the notches I wanted to use it on.
For instance, I used it on the door bars of the jeep that were at near 60* angles and at an odd intersection -- seemingly perfect. With how it sits over the tube, it was about a 1/4" bigger than the tube I was notching. After a few attempts of trying to get it to work right, I finally just used it as a start point and did the rest of the fitting with a grinder.
Maybe you could use a 1.5 pipe master for notching 1.75 tube and it would work in the high angle situations, but for the money they want for it, I dunno if it's truly worth it.
I agree that if you are doing more than adding a bar into something here or there, a notcher is worth the money.
Old April 4th, 2013, 09:30 AM   #20
Bones
Bones's Avatar
here are some of the joints that have little to no grinding.
Basically with 2" OD tube, to get a 90 degree joint, you set the chop saw at 30 deg and cut the tube so it makes a "C" to accept the joint (2 cuts 90 degrees to each other).
for 80 degree degree joint, you do a 35deg and 25 degree cut
at about 70 or 65 degrees, you have to start doing 3 cuts. I don't remember the angles, but the sample picture I took was a 65 deg joint and I think it used a 30 deg cut, 90 deg cut and 45 degree trim cut (just a little off the back of the joint for clearance). so 3 cuts per end of the tube, then flip it over and start whatever joint you need at the other end.
This was a 85 degree joint, I think the cuts were 33 deg and 27 deg or so. No grinding
this was around 80 deg
this has a 90 degree joint on the left (simple) and a 75 ish degree on the right that took 3 cuts for clearance.
here is a 65 degree 3 cut joint, not installed yet
For sure a tube notcher is a great tool, I am just trying to point out that you don't 100% need it for good, fast joints, unless you are doing this day in and day out.
ID:	104014   Click image for larger version
ID:	104015   Click image for larger version
ID:	104016   Click image for larger version
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Page generated in 0.55833 seconds with 85 queries
