92 chevy 350 tpi runs like crap - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 14th, 2013, 02:40 PM   #1
vteckickin
Default 92 chevy 350 tpi runs like crap
it runs like crap when warm if i unploug the coolint temp it runs a little better did a tune up yesterday still runs the same when its cold it runs great
vteckickin is offline   Reply With Quote
Old March 14th, 2013, 02:44 PM   #2
Toyfish
Toyfish's Avatar
change the coolant temp sensor
Old March 14th, 2013, 02:51 PM   #3
Little Dave
Little Dave's Avatar
I think we need a little more.
1: 92 what in a what?
2:Background just started it or ?
3: I think you get the idea.
I put a 91 tbi in my 84 cj7 with a 350. Timing caused me a lot of problems.
Little Dave is offline   Reply With Quote
Old March 14th, 2013, 03:05 PM   #4
vteckickin
92 chevy 1500 350 tip just did a tune up started about a week ago seems like its runing rich it blows black smoke
Old March 14th, 2013, 03:06 PM   #5
vteckickin
ive messed with timing didnt do anything for it
Old March 14th, 2013, 03:27 PM   #6
Little Dave
Ok did it run better before the tune up? Did the tune up fix anything? I ask because you did the tune up for a reason.
Old March 14th, 2013, 03:34 PM   #7
vteckickin
it was runing like this so i though it needed one so i give it one and didnt make a diffrence its loading up and when u rev it up it blows black smoke
Old March 14th, 2013, 03:49 PM   #8
Little Dave
Ok have checked for codes? My first thoughts are open loop that why Toyfish said collant sensor.
Old March 14th, 2013, 03:53 PM   #9
Iggy
Iggy's Avatar
There are too many things that could cause that. A leaky injector, a plugged return line, a bad temp sensor, the list could go on. Are there any codes being thrown? The best first step would be to hook up to a reader and see what the sensors are doing. If the engine is warmed up and the temp sensor reads -42*F, you have a bad Temp Sensor. If it is normal, look at the O2 reading and see if it shows a rich condition (which you have), if it does not - you may have a bad O2 sensor. If the sensors check out, you either have an injector that is leaking down fuel, or your pressure is too high causing the injectors to spray too much fuel. If a return line is plugged, the only path the fuel has is to spray out the injectors.
Iggy is offline   Reply With Quote
Old March 14th, 2013, 04:10 PM   #10
sanman
sanman's Avatar
Change the pig tail that plugs into the coolant temp sensor they have had problem's with them i would bet it would take care of your problem.
sanman is offline   Reply With Quote
Old March 14th, 2013, 05:17 PM   #11
Toyfish
Toyfish's Avatar
Autozone sells a sensor and pigtail combo pretty cheap
Sent from my DROID X2 using Tapatalk 2
Old March 14th, 2013, 05:55 PM   #12
vteckickin
changed the idle air didnt make a diffrence on my way to the parts store now for a coolint tamp
Page generated in 0.28859 seconds with 59 queries
