Murphy, the B2 build - Page 8 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 3rd, 2013, 08:20 PM   #141
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Lower links mocked up, crossmember in place, not finished yet. Still have some gussets, trimming and welding to do
Upper link made, 1.75, 1/4 wall dom, bushings on one side, 7/8 Heim on the other. Trackbar is the same.
Springs showed up, 5.5 super flex eb coils
Made all my upper link mounts and frame side trackbar mount. Not sure what I'm doing on the axle side. I need to make coil buckets too for the frame.
Hope to make some progress tomorrow.
Old May 3rd, 2013, 08:26 PM   #142
tonka toy
It's got a HEMI!
tonka toy's Avatar
I might have some stock coil buckets from a 79 F150 in the barn if you think they will work I can see if I still have a set.
Always missed, Never forgotten
FullSize4Life
08' 4door JK 5.7 hemi, auto, atlas and tons
2012 F350 6.7 PSD CC shortbox
tonka toy is offline   Reply With Quote
Old May 3rd, 2013, 08:28 PM   #143
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Yes! I would much rather use those than fab up a new set. Please look, I'll buy you lunch one day.
Let me know what you want for them.
Old May 3rd, 2013, 08:43 PM   #144
tonka toy
It's got a HEMI!
tonka toy's Avatar
I plan on going to lunch with you guys on Monday so I will let you know if I have them and if I do I will bring them with me.
FullSize4Life
Old May 3rd, 2013, 08:59 PM   #145
Otherwise I have a pair of early bronco buckets here you can have as well.
Old May 3rd, 2013, 09:14 PM   #146
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Put them in you explorer, I'd like to try them too. You guys rock
Old May 3rd, 2013, 09:18 PM   #147
They are still attached to the frame . It won't fit in the explorer.
Old May 3rd, 2013, 09:52 PM   #148
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Lol, well I guess if James can't find his, ill remove them on a buggy build day.
Old May 4th, 2013, 12:26 AM   #149
thrill20
thrill20's Avatar
I have adjustable ballistic frame mounts that you can have for cheap also....
thrill20 is offline   Reply With Quote
Old May 4th, 2013, 10:42 AM   #150
tonka toy
It's got a HEMI!
tonka toy's Avatar
Kyle I just looked for those buckets and I'm thinking that they must of went with the last load of scrap. So you will have to grab the ones John or Will have.
FullSize4Life
Old May 4th, 2013, 03:40 PM   #151
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Bummer
Ok, Will, pm sent.
Old May 4th, 2013, 07:35 PM   #152
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Made lots of progress today.
Got all the front suspension mocked up. 36" long links, all of them, 8.5" separation at the axle, 4" at the frame. That is about all I could fit, hope it works good with the 100" wheel base. The crossmember is installed, fully welded, just need to take the center out and finish the driveshaft clearance. Also got all the body mounts fixed, front frame horns replaced, still unsure on bumper, just put a tube in there to hold everything.
Pictures
Mostly finished crossmember
Plated frame for trackbar mount
Trackbar mount mocked up
3 link. At about full bump, 3" of uptravel right now, limited to my trackbar clearance. Gonna tweek that more to get about 4" of uptravel
The front frame fixed
Tomorrow hope to work on the rear axle. Gonna shave it and finish weld everything.
Old May 4th, 2013, 08:28 PM   #153
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Doing great work buddy
Old May 4th, 2013, 09:15 PM   #154
Shotgun
I only wheel with boats.
Shotgun's Avatar
I gotta get mine back over for shock mounts.
Old May 4th, 2013, 09:18 PM   #155
big86inthestixx
big86inthestixx's Avatar
Looks great. As always top notch fab work! Super clean work.
sended frum dis stoopid fone.
Old May 4th, 2013, 10:38 PM   #156
KennyOffroad
Ridge Runners Offroad
KennyOffroad's Avatar
Looking Nice !
Old May 5th, 2013, 03:12 PM   #157
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Thanks guys....keeping me motivated
14 bolt shaved
Everything welded up, u bolts trimmed to length, waiting for paint to dry. Also I welded the spiders in the rear. Hope to get it back together and installed this week.
Next in the list is coil buckets, boxing link mounts, then assembly. If things go good, maybe I'll start on drive shafts.
Old May 5th, 2013, 03:27 PM   #158
tonka toy
It's got a HEMI!
tonka toy's Avatar
I have 3 more drive shafts for you if the doc lifts my weight restrictions tomorrow morning I will bring them to lunch for you.
FullSize4Life
Old May 5th, 2013, 03:57 PM   #159
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Sweet, thanks!
Have your wife go load them for you....
Old May 5th, 2013, 04:26 PM   #160
Looks great kyle.
Page generated in 0.43672 seconds with 84 queries
