Murphy, the B2 build - Page 6 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 7th, 2013, 07:49 PM   #101
Grassman
2jz specialist
Grassman's Avatar
Duh, I Forgot About The Upgrades Lol
Mind Playing Tricks On You? Hard To See On The Phone. Cut Sleeve And Truss The Long Side Maybe?
Old April 7th, 2013, 07:50 PM   #102
Your looking off the tie rod mounting locations, did you actually check off the upper and lower ball joints? Maybe the kknuckles are slightly different but the actual location of the ball joints is the same...ie caster is actually the same in both sides.
Old April 7th, 2013, 07:57 PM   #103
94rangeron35s
bought a Jeep
94rangeron35s's Avatar
My thoughts also
Old April 7th, 2013, 08:10 PM   #104
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
No, you can see the c is twisted, it is obvious looking down on the balljoints.
The tierod mount just shows it by picture.
Old April 7th, 2013, 08:42 PM   #105
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Drivers side, 5* back
Passenger side, 5* forward
Kinda hard to tell by pictures, but the passenger side is clearly rotated forward.
Old April 7th, 2013, 08:50 PM   #106
Grassman
2jz specialist
Grassman's Avatar
Did A Woman Drive The Dodge?
Old April 7th, 2013, 08:56 PM   #107
frdboy
frdboy's Avatar
Typical dodge stuff, they have looser tolerances than others...
Old April 11th, 2013, 07:54 PM   #108
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Axle stripped and ready to be twisted back
As i was stripping it I noticed the twisted area, the housing next to the tube you can see the tube twisted
Gonna replace balljoints, u joints and a wheel bearing while its apart.
Old April 12th, 2013, 07:28 PM   #109
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Got the axle twisted back, then I cleaned it up, pre heated it and welded the tubes to the housing. I left it at work under a welding blanket to cool.
Time to get materials to build a truss.
The cut lines are marks I put in it before I twisted it back...moved a long way
Old April 12th, 2013, 08:42 PM   #110
liv2mx
i like jungle gym's.
liv2mx's Avatar
You get your wife to work on this yet kyle? She needs to get greasy.
Old April 12th, 2013, 10:14 PM   #111
Alex M.
Almazing
Alex M.'s Avatar
Haha not a chance. I work on him so I don't have to work on other stuff;)
Alex M. is offline   Reply With Quote
Old April 13th, 2013, 10:36 AM   #112
liv2mx
liv2mx's Avatar
Old April 20th, 2013, 12:21 PM   #113
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Had a good morning, got the rear shackle area built. The angle is a little steeper than I wanted, but I think it will be fine. Used a set of bushings, thanks thrill20, and some dom and boxed in the rear frame section.
Then I got a good start on the truss, I think I like the way this is going
Old April 20th, 2013, 12:26 PM   #114
thrill20
thrill20's Avatar
Looks good glad they worked out for you.
thrill20 is offline   Reply With Quote
Old April 20th, 2013, 01:54 PM   #115
Shotgun
I only wheel with boats.
Shotgun's Avatar
Nice man!
Old April 20th, 2013, 01:58 PM   #116
I see you finally got the lowers out
Old April 20th, 2013, 03:38 PM   #117
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Yes, but they fought me. New ones went in easy.
Old April 22nd, 2013, 08:43 PM   #118
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Got a little more work done on the truss
Added a couple gussets on the inside
Then started plating the top
It's all made of 3/16. Think I am going to add a couple drains in the back. Think I should hole saw a few holes in it, maybe sleeve them for strength?
Old April 23rd, 2013, 01:31 AM   #119
deathbypsi
Brian R.
deathbypsi's Avatar
That thing gona hit connecting rods at full stuff?
Old April 23rd, 2013, 04:49 AM   #120
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
It's not that tall...
Page generated in 0.42741 seconds with 84 queries
