*SOLD* 30gl diesel auxiliary / saddle tank *SOLD* - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 13th, 2013, 09:35 AM   #1
cornfed
I have an avatar. Yippee.
cornfed's Avatar
Default *SOLD* 30gl diesel auxiliary / saddle tank *SOLD*
My employer has seven tanks and three semi chassis mounting brackets available. $190 per tank and bracket set (only three sets available), $150 for tank only. Located in Ann Arbor, MI. PM for contact
ProPower Mfg. model 22CFR20R steel diesel fuel tank 30gl capacity, built-in gauge and sending unit, fill cap included. Feed and vent fittings are installed on tank. Feed and vent lines are not included or available.
Dimensions.
Tank: Diameter = 22" Depth = 20"
Maximum diameter (includes fittings and trap) = 25.5"
Maximum depth (includes filler neck) = 25"
Intended application was for reefer trailers or a semi-trailer equipped with a diesel generator. Increased capacity requirements for the intended application rendered these obsolete for my employers application.
Located in Ann Arbor PM for contact info.
cornfed is offline
Old March 13th, 2013, 06:28 PM   #2
mudbillyredneck
mudbillyredneck's Avatar
Dimensions ?
mudbillyredneck is offline
Old March 13th, 2013, 10:37 PM   #3
7.3X
Fullsize support vehicle
7.3X's Avatar
They are about that big can't you see?
7.3X is offline
Old March 14th, 2013, 01:42 PM   #4
cornfed
cornfed's Avatar
Updated.
cornfed is offline
Page generated in 0.15074 seconds with 35 queries
