Primer Help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 12th, 2013, 07:18 PM   #1
DZWrangler
DZWrangler's Avatar
Default Primer Help
I just finished up the body work for my nieces honda and I'll be painting the entire car for her as well. Does anyone have any ideas for primer that they have used in the past that I can use. So far I have used duplicolor and rustoleum sprayable primer and both have been garbage.
DZWrangler is offline   Reply With Quote
Old March 12th, 2013, 07:36 PM   #2
Marion3
Marion3's Avatar
2 part filler primer from painters supply
Marion3 is offline   Reply With Quote
Old March 12th, 2013, 07:48 PM   #3
sburt1928
zombie killer
sburt1928's Avatar
you want a sandable primer so you can block it out. a hi build sandable from finishmaster
sburt1928 is offline   Reply With Quote
Old March 12th, 2013, 07:51 PM   #4
Dylan
Dylan's Avatar
this is normally what I use.
http://www.autobodytoolmart.com/tran...FYpDMgod82UAlQ
Old March 13th, 2013, 03:28 PM   #5
Red97
if you have bare metal showing, use an etch primer shopline jp 215 or, NOT and. a epoxy primer shopline jp375. if you have small to light imperfections use a 2 part acrylic urathane primer shopline jp 202. if you have medium to large imperfections use polyester primer. basically spray filler. jp 205. all of these are at painters supply store. all are 125$ a gallon/kit or less. epoxy primer has the best corrosion protection on bare metal, it just dosent build and sand as well as the acrylic, or polyester primer. you can also reduse the epoxy primer and spray it as a sealer. if you dont use shopline brand/ppg those are still the same components in every diffrent brand of primers to look for.
Red97 is online now   Reply With Quote
Old March 13th, 2013, 04:15 PM   #6
DZWrangler
DZWrangler's Avatar
Thank you red97 thats exactly what I was looking for numbers and all!
Old March 13th, 2013, 05:32 PM   #7
Red97
No problem
Old March 13th, 2013, 05:43 PM   #8
GearDrive
A little slow
GearDrive's Avatar
If you use the epoxy primer, you should recoat it with 2k primer within 72 hours, or you will have to sand it.
GearDrive is offline   Reply With Quote
Old March 13th, 2013, 08:32 PM   #9
Red97
Or paint it. in that 72 is hour window. Also one thing i forgot about most epoxy's is the 15 min induction period after you mix it but before you spray it. Just make sure you get the p-sheets at the paint store for which ever products you end up getting.
Page generated in 0.29755 seconds with 50 queries
