Run it or not? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 11th, 2013, 06:55 PM   #1
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Default Run it or not?
Tearing my Ford 10.25 apart....getting ready to put it in my Toyota....noticed the pinion bearing was bad as the yoke wobbled....no big deal as i am planning 5.38's, full install kit, and welded before it goes in the truck....then i pull the cover and see that.....apparently pinion was loose enough to rape the carrier.....the marks are maybe a 1/16" deep at most.
My opinion is its not a big deal.
Thoughts?
Old March 11th, 2013, 07:34 PM   #2
yooper111
I'd run it. 10.25's are plenty strong, and if it does break, a carrier should be easy to find.
yooper111 is offline   Reply With Quote
Old March 12th, 2013, 06:43 AM   #3
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Anyone else?
Old March 12th, 2013, 06:46 AM   #4
jaysusr
jaysusr's Avatar
And if it does break, a carrier, new gears, install kit, someone to pull you out, a way to get on the trailer, will all be easy to find.
Old March 12th, 2013, 06:56 AM   #5
bigbchevy
missmrgreenagain
bigbchevy's Avatar
run it
H.o.r.e
Old March 12th, 2013, 08:31 AM   #6
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
I figure by the time i weld the spiders to the case and the pin and the side gears like the right ups on pirate suggest it will be one large chunk of metal and those marks will be of little consequence....but i am no expert so i ask.
On a side note....i can't seem to find a spool for it if i decide to go that route....anyone know if one exists?
Old March 12th, 2013, 09:29 AM   #7
I suck cocks. Lots of them.
locally famous
my street car did the same thing. run it.
Old March 12th, 2013, 09:34 AM   #8
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Not a bid deal by the looks of you horrible pic
If it's really only 1/16" deep cuts then I wouldn't worry at all.
Make sure to clean up the burrs on it tho just to eliminate metal shavings later in the axles life.
Old March 12th, 2013, 01:53 PM   #9
in2deep
Hole tester
flesh wound run it just make sure theres not metal thats going to fall of the carrier
Old March 12th, 2013, 04:54 PM   #10
joe_jeep
welfare wheeler
joe_jeep's Avatar
make sure there are no cracks in it. otherwise weld it, and run it!
no spools are available for the sterling. detroit, arb, or welded.
Old March 14th, 2013, 04:25 AM   #11
moparhorse
moparhorse's Avatar
That will work just fine. Ive seen worse run with a lot of power and daily abuse
moparhorse is offline   Reply With Quote
Old March 14th, 2013, 04:16 PM   #12
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Well i have like 80hp so i think i will be ok....weld it up and away i go.
I should prolly just get a 14 bolt but i have no money invested in this and o like that the bottom is much flatter than a 14 bolt which should offer better clearance so i'm gonna run with it
Page generated in 0.23566 seconds with 59 queries
