92 Jeep Wrangler Part Out - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > Great Lakes 4x4 Marketplace > Vehicle Part Outs
Old March 10th, 2013, 09:10 PM   #1
87yjmpi
Default 92 Jeep Wrangler Part Out
*****Updated 3/27*******************
Listing all the parts available from a recent part out. All parts listed were in working condition when removed. Parts will not be cleaned and are sold in as-is condition with no warranty or refunds. Some of these parts are 21 years old and are not new. All items are priced accordingly.
PayPal or local pickup in the south or west suburbs of Chicago with cash.
Will ship USPS or FedEx ground.
PM me if interested. If shipping is required please send me your zip as well co I can get back to you with a price shipped to your home. Discounts for purchasing multiple items.
All parts were taken off a 92 yj 4.0 5spd. White with Grey interior.
Body, Drivetrain, Top , Door, Wiring Harness and Wheels are gone. This is all that is left from this 92.
Most parts are interchangeable for all 87-95 but some are year specific. Please check to see if it will work for your specific year YJ
Interior
Speedo/ Tach bezel $15
Warning light cover $5
Center cluster bezel piece missing by stereo and heater controls $5
Black headlight switch bezel $10
Black solid bezel lower right of steering column $10
Factory radio brackets $10
Dash pad no cracks $35
Metal dash frame $30
Center gauge cluster in working condition SOLD
Heater box with heater core and blower motor. Needs 2 new thru firewall bolts $50
Upper heater box to cowl intake $20
Rearview mirror $10
5spd shifter cover plate with inner and outer boots. Some rips SOLD
Front Passenger side seatbelt with retractor ( male end ) $15 shipped doesn't spool out all the way
Rear complete seatbelt set male and female ends with hardware $80
Tailgate striker with hardware $5
Rear fold and tumble rear seat hardware complete with mounting hardware SOLD
Clutch/Brake pedal assembly $30
Gas pedal SOLD
Windshield to dash frame brackets SOLD
Wiper delay box relay $15
Smittybilt rollbar straps $15
Console with typical broken lid by mounting screws on lid SOLD
Steering wheel and horn cover SOLD
Body
Front headlight wiring harness. Complete from bulkhead connecter to passenger sidemarker light. Missing passenger side sidemarker bulb connector. SOLD
Rear lights with good lenses cracks on back of housings $20
Tire stop with mounting bolts $15
Rear bumperette $15
Steering, Suspension, Driveline, and Brakes
Front drive shaft from 4.0 w/Ax15 $45
Rear drive shaft from 4.0 w/Ax15 SOLD
Steering shaft column to box SOLD
Front rotors, pads, and calipers both sides very little wear. Only fits 91-95 not 87-90 wranglers $55
Brake booster with proportioning valve $35
Complete set of 4 leaf spring u-bolt plates $35
2" Lift Shackles set of 4 $60
Misc Items
Coolant overflow reservoir $15
Gas filler neck cover $5
Air intake tube of airbox $10
Fender mounted jack mount $10
Windshield hold down center hoop $5
4.0 Radiator Fan Shroud $40
87yjmpi is offline   Reply With Quote
Old March 11th, 2013, 12:40 PM   #2
87yjmpi
Front seat base sold pending payment
Old March 11th, 2013, 07:59 PM   #3
87yjmpi
Front passenger seat base sold
Old March 13th, 2013, 12:36 PM   #4
87yjmpi
Bump
Old March 16th, 2013, 12:20 PM   #5
87yjmpi
*****Prices have been reduced 3/16 and new items added *******************
Interior
Center gauge cluster in working condition $65 ( Have video of all gauges functioning)
Heater box with heater core and blower motor. Needs 2 new thru firewall bolts $55
Rearview mirror $10
5spd shifter cover plate with inner and outer boots. Some rips $20
Rear complete seatbelt set male and female ends with hardware $90
Gas pedal SOLD
Family style rollbar from 92-95 with black pads. Small rust hole in drivers side center hoop pad. Price will go up after it is repaired. $160 ( Local Pickup)
Body
Hood with minor dents and scratches $50 ( Local Pickup will not ship )
Front headlight wiring harness. Complete from bulkhead connecter to passenger sidemarker light. Missing passenger side sidemarker bulb connector. $25
Rear bumperette $15
Rear drive shaft from 4.0 w/Ax15 $45
Steering shaft column to box $20 ( Small joint will need to be replaced 1/4" of play)
Front rotors, pads, and calipers both sides very little wear. Only fits 91-95 not 87-90 wranglers $60
Brake booster with proportioning valve $40
Set of 4 factory springs SOLD
Misc Items
Front frame cover with jeep logo. Small cracks on sides near mounting points and top. $10
Old March 17th, 2013, 01:53 PM   #6
87yjmpi
Leaf springs sold
Old March 18th, 2013, 09:46 AM   #7
87yjmpi
Rear seat mounting hardware sold
Old March 18th, 2013, 10:21 PM   #8
87yjmpi
Gas pedal sold
Old March 19th, 2013, 10:43 AM   #9
87yjmpi
Console, steering wheel, and windshield brackets sold
Old March 19th, 2013, 09:05 PM   #10
87yjmpi
Rear driveshaft SOLD
Old March 23rd, 2013, 02:39 PM   #11
87yjmpi
Rollbar sold pending payment
Old March 23rd, 2013, 10:03 PM   #12
87yjmpi
Hood sold
Old March 23rd, 2013, 11:37 PM   #13
87yjmpi
Shifter, shifter boot and cover SOLD
Old March 24th, 2013, 12:41 PM   #14
87yjmpi
*****Updated 3/24*******************
Interior
Rearview mirror $10
Gas pedal SOLD
Body
Rear bumperette $15
Misc Items
Old March 24th, 2013, 02:51 PM   #15
87yjmpi
Steering shaft and center gauge cluster SOLD
Old March 26th, 2013, 01:01 PM   #16
87yjmpi
Headlight wiring harness SOLD
Old March 27th, 2013, 04:28 AM   #17
87yjmpi
Interior
Rearview mirror $10
Gas pedal SOLD
Body
Rear bumperette $15
Misc Items
Old March 27th, 2013, 05:34 PM   #18
87yjmpi
Lift shackles SOLD
Old March 30th, 2013, 02:43 PM   #19
87yjmpi
Rear belts sold.
Old April 1st, 2013, 01:27 PM   #20
87yjmpi
Dash pad SOLD
Page generated in 0.63835 seconds with 83 queries
