How to fix a 6.0 powerstroke - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 14th, 2013, 04:57 AM   #21
moparhorse
moparhorse's Avatar
What all did you do to the pump itself?
moparhorse is offline   Reply With Quote
Old March 14th, 2013, 08:29 AM   #22
I suck cocks. Lots of them.
locally famous
problem solved... now your box will rot out.
Old March 14th, 2013, 09:22 AM   #23
firehawk
Live Action!
firehawk's Avatar
Just like a Dodge.
Old March 14th, 2013, 12:58 PM   #24
BenAbraham
BenAbraham's Avatar
I just disassembled cleaned and resealed
BenAbraham is offline   Reply With Quote
Old March 14th, 2013, 01:00 PM   #25
BenAbraham
BenAbraham's Avatar
Originally Posted by joe_jeep View Post
i assume the 6.0L was fubar?
Ya it needed 5 new injectors and a turbo.....it did have almost 200k, I bought the truck with intentions of converting it
Old March 14th, 2013, 01:41 PM   #26
Bones
Bones's Avatar
awesome! about time. It was the perfect conversion truck.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old March 14th, 2013, 09:11 PM   #27
BenAbraham
BenAbraham's Avatar
I have a question......
Does anyone know what size threads are on the radiator for the transmission cooler? I need an adapter to go to an, I know ford doesn't make the "push on" fitting anymore the thread size is around 11/16. I know that is should be metric which would be around 18 mm which would make sense but I don't have anything 18x1.5 to test it with.
Old March 14th, 2013, 09:32 PM   #28
BenAbraham
BenAbraham's Avatar
I forgot to say that everything shown in the previous photos was done at an apartment garage/parking lot. While I was on my co-op with Kohler Engines...
Here was a video of the first start after the rebuild with no turbo or manifold.
http://s1110.beta.photobucket.com/us...6DB64.mp4.html
I have been back at school since mid January and this is why I haven't got much done.
Old July 6th, 2013, 01:06 AM   #29
BenAbraham
BenAbraham's Avatar
Got most of the bugs worked out
http://youtu.be/pUkfru4EeCM
Old July 20th, 2013, 02:29 PM   #30
BenAbraham
BenAbraham's Avatar
I got the dash all back together
Old October 9th, 2013, 07:34 PM   #31
BenAbraham
BenAbraham's Avatar
I had a really bad powersteering leak when I checked it out I found this
So I removed just the reservoir and soldered it back up.
Repainted and replaced the accessible O-rings. Problem solved
Only real problem I have had.
Old October 10th, 2013, 07:36 PM   #32
Mclovin
"The Situation"
Mclovin's Avatar
you said all the cluster gauges work ? why the volt gauge on the A pillar ?
Old October 11th, 2013, 04:05 PM   #33
BenAbraham
BenAbraham's Avatar
The stock one reads L to H what does that tell you?
Old October 18th, 2013, 08:39 PM   #34
BenAbraham
BenAbraham's Avatar
Default How to fix a 6.0 powerstroke
Here's my mileage log
MPG
DateOdometer Miles Gallons M.P.G Notes
9/27/2013198606
10/10/2013199209 603 31.55619.10888579 Breaking the truck in
10/12/2013199817 608 27.34322.23603847 Round trip to Sheboygan WI
I was pleasantly surprised about the 22.2 Mpg. I feel there are 4 reasons I am getting such great mpg
1. I have the timing advanced and with the big bowl pistons and stock injectors the spray is still hitting within the bowl.
2. I have a manual with 3.54 I believe
3. I had an head plate put on the engine block before honing the bores
4. I have a huge exhaust housing which sucks for spool up time but is great for mpgs (21cm^2)
Old October 23rd, 2013, 05:48 PM   #35
BenAbraham
BenAbraham's Avatar
MPG
Date Odometer Miles Gallons M.P.G Notes
9/27/2013 198606
10/10/2013 199209 603 31.556 19.109 Breaking the truck in
10/12/2013 199817 608 27.343 22.236 Round trip to Sheboygan WI
10/20/2013 200415 598 29.914 19.991 Mixed
Old October 24th, 2013, 02:16 PM   #36
crunchedtj99
awesome build.... as advice for someone else about to do this swap anything you would do differently if you did it again??? granted mine is a little older f250 but def going to swap a cummins into my ford this winter
crunchedtj99 is offline   Reply With Quote
Old October 30th, 2013, 02:14 PM   #37
BenAbraham
BenAbraham's Avatar
I would not rebuild the engine before using it, too many variables
Make as many parts as you can, If I were do to in again the only thing I would buy is the adapter plate, the motor mounts from the various manufactures would be easy to replicate and improve on.
I would definitely use a manual or a non electric automatic
Old October 31st, 2013, 02:12 PM   #38
Cartman
Can't lose with 42s
Cartman's Avatar
I doubt having a torque plate installed during honing is giving you notable MPG gains
sweet build though!!!
Nothing wrong with the VE pump
Cartman is offline   Reply With Quote
Old January 2nd, 2014, 09:16 PM   #39
BenAbraham
BenAbraham's Avatar
2013 mileage log
MPG
Date Odometer Miles Gallons M.P.G Notes ppg
9/27/13 198606
10/10/13 199209 603 31.556 19.109 Breaking the truck in 3.699
10/12/13 199817 608 27.343 22.236 Round trip to Sheboygan WI 3.669
10/20/13 200415 598 29.914 19.991 Mixed 3.659
10/27/13 200862 447 24.067 18.573 Some 4x4 snow tires 3.699
October 2256 112.88 19.986 3.682
11/3/13 201336 474 24.268 19.532 Mixed no 4x4 3.609
11/15/13 201798 462 26.051 17.734 no trips 3.719
11/22/13 202261 463 24.385 18.987 Some 4x4 snow tires 3.999
11/25/13 202801 540 28.792 18.755 some 4x4 trip to MC 3.669
11/28/13 203313 512 27.136 18.868 mixed plus trip 3.999
November 2451 130.632 18.763 3.799
12/6/13 204037 724 39.473 18.342 lots of 4x4 plus trip 3.669
12/13/13 204457 420 25.253 16.632 All 4x4 3.659
12/23/13 205171 714 40.029 17.837 Trip home 3.999
12/29/13 205848 677 37.476 18.065 Trip home & home 3.859
12/29/13 206121 273 16.871 16.182 Trip back 4x4 3.959
December 2808 159.102 17.649 3.829
2013 7515 402.614 18.666 3.770
Page generated in 0.45523 seconds with 81 queries
