How to fix a 6.0 powerstroke - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 10th, 2013, 01:00 PM   #1
BenAbraham
BenAbraham's Avatar
Default How to fix a 6.0 powerstroke
The truck, 2005 fords F350 Crew Cab long XL, manual transmission, manual transfer case.
The problem
This has become too familiar to me
The solution
BenAbraham is offline   Reply With Quote
Old March 10th, 2013, 01:25 PM   #2
BenAbraham
BenAbraham's Avatar
Old March 10th, 2013, 01:36 PM   #3
BenAbraham
BenAbraham's Avatar
The engine rebuilt 1991.5 cummins, 20 over, main and head studs
destroked engine mounts and and adatper plate
southbend clutch dual disk
Old March 10th, 2013, 02:00 PM   #4
bigjay
The Man Myth And Legend
bigjay's Avatar
Location: i can piss on the allegan and barry county line at the same time.. ...
interesting. will the electronics for the dash still work?
bigjay is offline   Reply With Quote
Old March 10th, 2013, 02:10 PM   #5
BenAbraham
BenAbraham's Avatar
Ya they all will, right now the water temp, oil pressure, volt, and speedo work. I have to still buy a kit for the tach and hook up the boost gauge.
Old March 10th, 2013, 02:17 PM   #6
bigjay
bigjay's Avatar
was thinking of doing this to my 00 7.3.. but with 103k on it i have awhile.. unless something catastrophic happens. would be nice to have something that could be easily modded in the truck tho
Old March 10th, 2013, 02:22 PM   #7
BenAbraham
BenAbraham's Avatar
My goal with this truck is simple reliability. When I am done I will be able to pull start and drive the truck with out any batteries.
Old March 10th, 2013, 02:31 PM   #8
bigjay
bigjay's Avatar
E.M.P proof....is the motor going to make around the same numbers as the 6.0 or is it closer to what the cummins was stock?
Old March 10th, 2013, 03:55 PM   #9
BenAbraham
BenAbraham's Avatar
The final goal is 400hp 1000ft-lb but with the stock turbo I am limited right now.
Old March 10th, 2013, 04:20 PM   #10
1TFROT
1TFROT's Avatar
I don't know much about the cummins, but that seems odd to me. I'm on a stock turbo and make #s way higher than that with my duramax.
should be interesting in final #s like fuel economy and such once it's done. sure will be tons more reliable that's for sure.
good luck with the build.
love the V8 pic
1TFROT is offline   Reply With Quote
Old March 10th, 2013, 04:29 PM   #11
bigjay
bigjay's Avatar
He's also running a first gen cummins that made about 170hp and 400ft tq..stock u cant compare a v8 duramax to it.
Old March 10th, 2013, 04:38 PM   #12
1TFROT
1TFROT's Avatar
that's why I said what I did. not familiar with the cummins so I wasn't sure what the limitations are for the stock turbo what he was starting with
cool build and it should be a very reliable truck after he's done. several friends of mine all have issues with their 6.0 fords.
Old March 10th, 2013, 05:06 PM   #13
Elusive
Elusive's Avatar
Problem solved.
Ford, Good job testing those motors before selling hundreds of thousands of trucks equipped with complete junk.
Elusive is offline   Reply With Quote
Old March 10th, 2013, 05:17 PM   #14
bigjay
bigjay's Avatar
Not a bad motor just takes money to make them reliable...lol
Old March 10th, 2013, 06:44 PM   #15
69-power-wagon
69-power-wagon's Avatar
That makes it a bad motor. They're flawed from the beginning with only 4 head bolts per cylinder instead of 6
69-power-wagon is offline   Reply With Quote
Old March 11th, 2013, 12:40 AM   #16
cheapcherokee91
"cant worry about it"
cheapcherokee91's Avatar
awesome build man. only fix for my 6.0 was trading it in
cheapcherokee91 is offline   Reply With Quote
Old March 11th, 2013, 10:44 AM   #17
disturbedsledneck
disturbedsledneck's Avatar
Cool build! Should be real reliable and simple to work on now.
disturbedsledneck is offline   Reply With Quote
Old March 12th, 2013, 08:43 AM   #18
Finally someone doing something practical with a ford.
Old March 12th, 2013, 02:55 PM   #19
knaffie
knaffie's Avatar
Sweet project.
Old March 12th, 2013, 04:50 PM   #20
joe_jeep
welfare wheeler
joe_jeep's Avatar
i assume the 6.0L was fubar?
Page generated in 0.52088 seconds with 84 queries
