Herman (mrslousypirate's xj) - Off to new owner - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 1st, 2013, 01:25 AM   #41
Lousypirate
Whoop Whoop
Lousypirate's Avatar
Originally Posted by jbsjunk View Post
Dodge trucks?
I sure hope I'm the saint of something cooler than dodge trucks
Old January 4th, 2014, 02:41 PM   #42
Lousypirate
Whoop Whoop
Installed for led spot lights on the bumper today. Only casualty was my pinky finger. But that was because I was opening up the shackle mounts.... drill grabbed and pinched some skin off.
Old January 4th, 2014, 03:37 PM   #43
Lousypirate
Whoop Whoop
No lights
Low beam
High beam
High beam plus led
Led's only
Genssi lights from Amazon.
Old January 4th, 2014, 03:44 PM   #44
jbsjunk
Little Member
jbsjunk's Avatar
Dammit. I'm blind now.
Old January 4th, 2014, 04:21 PM   #45
GREASYHANDS
GREASYHANDS's Avatar
Cool
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old January 4th, 2014, 05:48 PM   #46
curbdog17
Mini Van
curbdog17's Avatar
Nice
Old January 4th, 2014, 06:28 PM   #47
Lousypirate
Whoop Whoop
I kinda want someone to flash their brights at me lol
Old January 4th, 2014, 07:16 PM   #48
Jeep_Shaun
Don't Fear The Jeeper
Jeep_Shaun's Avatar
looking good
Jeep_Shaun is offline   Reply With Quote
Old January 4th, 2014, 07:56 PM   #49
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
I see spots.....
Old January 4th, 2014, 09:18 PM   #50
srlbotanical
Because I Said So...
srlbotanical's Avatar
It's so much clearer with just the LED's....
srlbotanical is offline   Reply With Quote
Old January 5th, 2014, 06:48 AM   #51
curbdog17
Mini Van
curbdog17's Avatar
Old January 5th, 2014, 08:47 AM   #52
Lousypirate
Whoop Whoop
One or two of my pictures were fuzzy...
Old February 11th, 2014, 09:48 PM   #53
Lousypirate
Whoop Whoop
Did the hood lift mod.
Thanks to Greasyhands for giving me some struts, because I broke one of the rears replacing them...
Old February 11th, 2014, 10:05 PM   #54
GREASYHANDS
I'm glad someone found use for the stuff I collected over the years. So how about a detailed write up of how you did it.....
Small pic is small
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old February 11th, 2014, 10:13 PM   #55
jbsjunk
Little Member
jbsjunk's Avatar
Copycat. You don't have to dodge the prop rod anymore.
Old February 11th, 2014, 10:20 PM   #56
Padilen
Padilen's Avatar
This was going to be my first mod to my KK. I've still not done it.
So nice job!
Padilen is offline   Reply With Quote
Old February 11th, 2014, 10:31 PM   #57
fordbronco
the ocean called
fordbronco's Avatar
Nice mod!!
Old February 11th, 2014, 10:54 PM   #58
Lousypirate
Whoop Whoop
Small pic is small
click on the pic, not small for me
there are a bunch of writeups on le google.
I took the brackets off my 97-01 and threaded them onto the older style xj struts. They are a shade longer, and I ended up mounting them "upside down" to work with the newer style mounting bracket.
I then took self tapping screws and lined them up with the flat inside the fender, there was a small dimple in the sheet metal, so I used that to place my rear bolt on the bracket.
for the hood side the longer old style struts work better because they were a little longer. the new style strut put it directly where the notch in the hood brace is (no good). to get the bracket below you're looking at an almost vertical hood. To put it above the notch the angle of the hood is less than desirable. I purchased a pair of 10mm ball brackets from amazon (here) and drilled and pop riveted it to the hood.
Some people have clearance issues with the washer fluid fill port, I didn't seem to. It did hit the wiring harness on the drivers side, but I moved it around and no problem.
Good enough for you scott?
The hood really bangs open when you pop the latch now I'm not sure if my wife is capable of reaching the hood to close it now
main reason for it. I got sick of how cumbersome the hood is to prop with the stock rod. It is currently laying on the garage floor
So nice job!
get it done
I did this in about 20 minutes of work time. I spent more time looking for rivets and eventually driving to the parts store (needed to pick up a fuel pressure regulator anyways)
Originally Posted by fordbronco View Post
Nice mod!!
Old February 11th, 2014, 11:06 PM   #59
fordbronco
the ocean called
fordbronco's Avatar
I can see one of your struts failing prematurely. I suppose i could take that XJ off your hands so you aren't stuck with it...
Old February 11th, 2014, 11:14 PM   #60
Lousypirate
Whoop Whoop
everything's for sale for the right price
Page generated in 0.31091 seconds with 84 queries
