1986 k30 (NOT PARTING OUT) decided to keep - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > Great Lakes 4x4 Marketplace > Vehicle Part Outs
Old March 9th, 2013, 09:19 PM   #1
656owner
656owner's Avatar
Default 1986 k30 (NOT PARTING OUT) decided to keep
Unsure if I want to part this truck out yet, seeing what kind of response I get.
This truck has a 6.2 diesel with 45K miles, has dana 60 front with lock outs, rear is a 14 bolt full floater, both have 4:56 gears and the rear has a detroit locker. Turbo 400 trans with a NP208 t-case, new rear drive shaft. Body is ok some minor rust and dents. Radiator has slight leak.
Call 616-896-9956
Mechanically this truck seems great!
Front clip $400
Bed $500
Cab $600
Transmission $300
Engine $1000
Transfer case $100
open to offers.
I want to keep the axles unless I am given a good offer.
Keeping the truck together so that anyone interested in the engine can see it run.
656owner is offline   Reply With Quote
Old March 10th, 2013, 03:22 PM   #2
spectreblazer
spectreblazer's Avatar
will the 208 work with a turbo 350? i have a 203 behind it right now and its got shift issues. also would you sell the crossmember for it? i believe the 203 and 208 used different ones but not 100%
spectreblazer is offline   Reply With Quote
Old March 10th, 2013, 08:12 PM   #3
656owner
656owner's Avatar
From the little bit I know the out put shaft of the TH350 needs to be a certain length. I do not know if it will work with it to put it short, but I do have another 203 I do not need. Was also on a TH350. $80.
Old March 10th, 2013, 08:46 PM   #4
fabricator
throttle jockey
fabricator's Avatar
does this truck have the firewall insulator pad on it? it covers the whole firewall on the engine side and cuts down on the motor noise. its only on diesel 6.2 trucks, but i dont know if its on the military trucks
fabricator is offline   Reply With Quote
Old March 11th, 2013, 04:51 AM   #5
656owner
656owner's Avatar
There is no fire pad on this truck. Never seen one on a military truck.
Old March 12th, 2013, 03:21 PM   #6
Iggy
Iggy's Avatar
On the TH350 vs TH400, the spline count of the output is different.
Iggy is offline   Reply With Quote
Old March 12th, 2013, 07:18 PM   #7
spectreblazer
thanks for the info
Page generated in 0.25079 seconds with 44 queries
