Temporary Transmission Fixes - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 8th, 2013, 02:29 PM   #21
Bones
Bones's Avatar
the sap from the pine is the secret though. it re-coats all the bands.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old March 8th, 2013, 02:36 PM   #22
JeepInABox
In too deep
JeepInABox's Avatar
Trans medic always fixed hard seals and slow shift issues
It pours like water and will not ruin it like saw dust
If it's something else it won't make it any worse
Old March 8th, 2013, 02:37 PM   #23
Red68Camaro
End nerd persecution
Red68Camaro's Avatar
Originally Posted by hosejockey4506 View Post
Dont listen to this guy he is dumb,
Do the saw dust trick i found that chain saw shavings from a oak tree works the best as pine is to soft
x2.........
Red68Camaro is offline   Reply With Quote
Old March 8th, 2013, 02:55 PM   #24
bbaXJ
Yooper In Training
bbaXJ's Avatar
Originally Posted by Tranny Tom View Post
Before you try any of these bullshit fixes, please figure out what trans it is and report back. I can try and help you figure out the actual problem and probably fix it so it will last the race. Is it shifting through all gears? Taking off in first? Taking off in a higher gear? Ect.
I'll get a pic for you tonight. I only drove it about 150 yards so far so my details are minimal till it's unloaded tonight. Got it from dline on here and have dealt with him before so trust his assessment. It's been daily driven the way it is now, goes through the gears, but shutters at higher speeds when getting into the throttle. Loading it onto the trailer it didn't want to move at idle, but would take off fairly suddenly once the RPMs got up a bit more. Like I said, it felt like there was a stall converter in it. I'll take pics later, go for a drive, and give more detail.
bbaXJ is online now   Reply With Quote
Old March 10th, 2013, 12:48 PM   #25
dreezy
Haggard Fab
dreezy's Avatar
Is the fluid level low?
Shazam Bitches
Old March 10th, 2013, 01:40 PM   #26
huntstoomuch
Always chasing a big rack
huntstoomuch's Avatar
Count the pan bolts to ID the transmission...
14 pan bolts = AOD
16 pan bolts = AODE or 4R70W
17 pan bolts = C6
18 pan bolts = A4LD
20 pan bolts = E4OD
huntstoomuch is offline   Reply With Quote
Old March 10th, 2013, 03:10 PM   #27
bbaXJ
Yooper In Training
bbaXJ's Avatar
After a test drive it's been decided to not even mess with it. It goes great in first and second, but feels pretty nasty and slips and shudders like crazy at higher gears/speeds. The first 2 gears should be all that's needed for its intended purpose, so gonna leave it alone and not risk making it worse.
Old March 10th, 2013, 04:15 PM   #28
Nuggets
I fix stuff!
Nuggets's Avatar
I'd like someone to explain how sawdust cures pump, band, or clutch issues. Please explain the full process using all the big, technical words that you feel neccessary to explain the process, don't worry, I'll understand. My thought's: This process is utter bullshit and can not be verified.
The brake fluid fix: There is some validity to this "trick". The materials used to seal various components in the transmission do not like brake fluid. The brake fluid pisses off the sealing material causing it to slightly swell therefore potentially inproving the seal of the component that is having issues.
Old March 10th, 2013, 04:24 PM   #29
BigBird
Duck Shootin' Wheelerer!!
BigBird's Avatar
I was wondering this same thing???:banghead:
Cheap Thrills Off Road
Old March 10th, 2013, 04:43 PM   #30
wilesin
10ptbuck
wilesin's Avatar
It works the same way, by tightening clearances. Plus it not just any sawdust, its oak although I have had some luck with walnut. So before you go getting all Mr. Smartypants give it a try.
wilesin is offline   Reply With Quote
Old March 10th, 2013, 05:06 PM   #31
SS
Bananarama!
SS's Avatar
Bingo.
All I know is that the Excursion we used that trick on didn't move an inch because the trans slipped so bad. We added the saw dust and it was doing burn outs in the parking lot for about a hour before all the chunks clogged up the valve body.
-Jer
SS is online now   Reply With Quote
Old March 10th, 2013, 06:32 PM   #32
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
I'd like to see how sawdust could even get past the filter in an automatic transmission. must be some special dust to get around the filter and into the internal components of the transmission. whatever jackass even thought of that should be smacked for trying to spread mis-information that could cause even more destruction in a transmission.
Old March 10th, 2013, 06:58 PM   #33
SS
Bananarama!
SS's Avatar
No shit it causes more damage. No one is saying its a quick fix for the long term.
How is it misinformation if the truck didn't move... saw dust was added... the truck moved?
-Jer
Old March 10th, 2013, 08:39 PM   #34
Immortal
NO RELIGION WAT!
Immortal's Avatar
It's JF all over again
http://www.jeepforum.com/forum/f19/s...ssions-323729/
Old March 10th, 2013, 09:55 PM   #35
wilesin
10ptbuck
wilesin's Avatar
How are rainbows made? Why's the sky blue? How does a posi trac rear end in a plymouth work? It just does.
Old March 10th, 2013, 11:33 PM   #36
bbaXJ
Yooper In Training
bbaXJ's Avatar
My guess is that besides blocking passages and sealing seals, it could also *potentially* have enough grit in it to add miniscule amounts of friction back in to where it has been lost from worn out components. In new/working form a trans should have friction elements and the fluid acts as a lubricant. In a worn out trans the friction materials in some area or another are gone, so grit is added to the fluid to help these worn out places grab better. Granted, I've never tried it and for every 1 story of it working there are probably 10 of it failing, but its an interesting idea. This is pure specultion on my part, but I can see how it *could* work as a very short term "fix"
Old March 10th, 2013, 11:36 PM   #37
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
well then try saw dust after said weekend and report back the results
Old March 11th, 2013, 12:11 AM   #38
SS
Bananarama!
SS's Avatar
Exactly.
I can only testify to what I have experienced personally and if saw dust allowed a stripped out transmission connected to a 7.3L Powerstroke to do burn outs in a parking lot it's a pretty good indicator that it works as a short term solution.
If you've never tried it and scoff at the idea of it working simply because it sounds absurd...
Let me ask you a question...
Do you believe in the works of Jesus and the Bible?
-Jer
Old March 11th, 2013, 02:03 AM   #39
Nuggets
I fix stuff!
Nuggets's Avatar
So what is the mechanism that causes the swelling of the seals? How does the sawdust get past the filter so it can effect said seals? What keeps the filter from getting plugged? If the sawdust gets past the filter, how does it keep from plugging up small orfices, channels, and checkballs?
As far as trying it, I currently don't have any questionable transmissions I wish to sacrafice. Please feel free to give me a live demonstration to prove the validity of your statement. I have no problem with being proven wrong and will be happy to concede to your superior knowlege of backwoods ways to fix things.
Old March 11th, 2013, 02:17 AM   #40
Nuggets
I fix stuff!
Nuggets's Avatar
Rainbows: Sunlight flowing through falling droplets of rainwater is seperated into it's visible spectrum elements due to the prisim effect of water, ergo polychromatic light is reduced to monochromatic light.
Why is the sky blue?: Sorta like the same effect as above. Molecules of air tend to scatter the blue component of polychromatic light (white light) farther than other components of the visible spectrum. More blue light reaching the eye means the sky appears blue.
Positrac in a Plymouth: Short answer because I have to get to bed - Exactly the same way as it does in a chevy. inb4herpderpyoudon'tknow
Page generated in 0.45004 seconds with 82 queries
