***SOLD****. AMC 401 v8, TF 904 trans, D300 tcase, wide-track axles - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 7th, 2013, 08:14 PM   #1
disturbedsledneck
disturbedsledneck's Avatar
Default ***SOLD****. AMC 401 v8, TF 904 trans, D300 tcase, wide-track axles
1974(?) Jeep AMC 401 V8 - Upon tear-down inspection, found there is a crack in the no 4 cylinder wall. Crank, rods, heads all good. Has factory 4 barrel intake w/ 4 bbl Motorcraft carb. Also, exhaust manifolds, and front accessories including power steering pump. Stored in doors. Still on a stand and apart for inspection. Cylinder may be able to be repaired, sleeved possibly.
$250 obo engine sold
Built TF 904 automatic trans & Dana 300 transfer case - Trans has reverse-manual valve body, clutches, stall converter. Pulled from running/driving 6-cylinder CJ-5about 5 years ago. Stored in doors.
$350 obo trans & t-case combo sale pending on trans
1986(?) CJ-7 wide-track axles, Dana 30 f, AMC 20 r. These were pulled from a running, driving CJ-7 with a 2.5 4-cylinder. There is an "A" stamped on the housing near the axle tube, meaning 3.54 gears. They have been sitting a few years outside, will need to be checked over again.
$150 pair sale pending
Please no calls after 10 pm - Located in Vassar 48768
989-280-8095 call or text
ID:	102846   Click image for larger version
Last edited by disturbedsledneck; March 10th, 2013 at 11:51 AM. Reason: Update axle ratio (Thanks, Haggar)
disturbedsledneck is offline
Old March 7th, 2013, 08:32 PM   #2
Bo's Cj 7
Bo's Cj 7's Avatar
Default I am interested in your 401
I started to rebuild one and my crank is bad. If yours is good I will buy yours motor for asking price. My cell is 810 955 1834
Thanks Bo
Bo's Cj 7 is offline
Old March 7th, 2013, 08:33 PM   #3
pm'ing you...
Haggar is offline
Old March 7th, 2013, 08:40 PM   #4
michigan maniac
michigan maniac's Avatar
I'm interested in the intake if wanna sell it on the side
michigan maniac is offline
Old March 8th, 2013, 10:00 PM   #5
disturbedsledneck
AMC 401 is SOLD
4bbl intake and carb is still available, $50
Trans and axles are pending
Old March 9th, 2013, 01:22 AM   #6
Jcj5
Default Intake and carb
Very interested give me a call 8106273589 would like to come get this weekend if you still have it
Jcj5 is offline
Old March 9th, 2013, 05:52 PM   #7
disturbedsledneck
I texted you twice with no response.
Old March 9th, 2013, 05:53 PM   #8
disturbedsledneck
I Pm'd you.
Old March 10th, 2013, 11:50 AM   #9
disturbedsledneck
Axles, trans & tcase. SOLD
Page generated in 0.18736 seconds with 51 queries
