New member / new builder th350/np205 sm465 swap question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 7th, 2013, 01:29 PM   #1
nihilarian
Default New member / new builder th350/np205 sm465 swap question
Hello,
I'm new to the forum and am launching into my first somewhat serious 4x4 build. I recently picked up a '57 Willys wagon and a '73 K20 long bed (350 4bbl, th350/np205, d44 front, 14b rear). The plan is to shorten the frame from the chevy and drop the Willys body on top. The th350 has seen better days and reverse is non functional. I'd like to see a sm465 in place of it from which I plan to run a PTO, hydro pump and hydro winch. I've searched a lot and haven't found an answer to what I'll need to make the tranny swap. It sounds like I can use the stock crossmember location, but what I need to know is what I need to bolt my existing np205 to the sm465, and if there is a year range I should be looking for on the tranny. Or will I be better off just looking for a sm465/np205 set up? I can post some pictures later for anyone that's interested in my two heaps.
nihilarian is offline   Reply With Quote
Old March 7th, 2013, 01:32 PM   #2
MusKegon_ZJ_gurl
Extraordinarily Ordinary
MusKegon_ZJ_gurl's Avatar
Hello and Welcome!
...looking forward to a build thread on this one.
http://www.glfwda.org/
MusKegon_ZJ_gurl is offline   Reply With Quote
Old March 7th, 2013, 05:29 PM   #3
jbsjunk
Little Member
jbsjunk's Avatar
I'm no help but this is off the wall. I like the idea.
Old March 7th, 2013, 07:27 PM   #4
nihilarian
Here's a couple photos. Hopefully it inspires some knowledgeable passer by to help me with my question.
ID:	102843   Click image for larger version
ID:	102844   Click image for larger version
Old March 7th, 2013, 07:31 PM   #5
jhnyquest
goof ball
jhnyquest's Avatar
Sure like the willys.
Old March 7th, 2013, 07:33 PM   #6
capone
capone's Avatar
Welcome are you a member on http://www.oldwillysforum.com/ ?
Here's good build thread for you to read. http://www.cardomain.com/ride/380581...willys-pickup/
capone is offline   Reply With Quote
Old March 7th, 2013, 11:38 PM   #7
nihilarian
Thanks for the links. I checked the build thread out and it looks like it will definately be helpful. And yes, I am on oldwillysforum as well. I'll start a build thread soon. I've just been rebuilding the carb and collecting parts at the moment. Soon the work will begin.
Old March 8th, 2013, 07:08 AM   #8
nihilarian
Originally Posted by deerebowtie View Post
any 465/205 combo will work, 32 spline output is ideal (1984+) - hydraulic is easier to swap in, manual provides better pedal feel. stiffness of the pressure plate dictates how hard the pedal depresses.
parts you'll need for a hydro swap
flywheel
clutch
pressure plate
bolts for pressure plate
new throwout bearing
pilot bushing or bearing (bushing lasts longer)
longer crank studs
new gaskets
gear oil
your choice on the frame mount style, and don't forget the np205 torsion mount
master cylinder
speedway auto braided stainless hose and thread adapters
push or pull style slave cylinder options
-check this out and copy it or buy it, their kit utilizes a jeep cj slave
http://www.novak-adapt.com/catalog/clutch/kit_hcrc.htm
OR
http://www.speedwaymotors.com/Garage...-Bore,783.html
--you can figure out how to mount this up
while you have the 205 out is a perfect time to twin stick it.
manual linkage option
Thanks, thats great information. Can I use the np205 that I currently have on the th350? Will it bolt to the sm465 without an adapter? It sounds like I'll at least need a year range for the spline tooth count?
Old March 10th, 2013, 09:56 PM   #9
nihilarian
Can't anyone help me with this? I guess I'll find out when I go and buy a new tranny, but I'd really like to know if there's something I should be looking for before I dive in. Is there a sm465 that will bold to my np205 that's currently on a th350?
Old March 10th, 2013, 10:02 PM   #10
XJsport95
Haters be my motivators!!
XJsport95's Avatar
Try looking around on advanced adapters website. They might be able to help with what your looking for.
XJsport95 is offline   Reply With Quote
Tags
3threadsin1
Page generated in 0.21768 seconds with 54 queries
