Trac bar bushing replaced and still hopping - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 6th, 2013, 07:25 PM   #1
twelve
twelve's Avatar
Default Trac bar bushing replaced and still hopping
I've got a 1978 bronco. I did the trac bar bushings and it still hops when driving. the passenger side radius arm bushing was just relpaced when i got it and i have the bushings for the other side but it doesn't look bad. Could the axle be crooked beacuse of this? I'm gonna check the wheel bearings, rotors, ball joints, and steering. Is there anything I'm not thinking of?
twelve is offline   Reply With Quote
Old March 7th, 2013, 10:03 AM   #2
twelve
twelve's Avatar
Any suggestions guys?
Old March 7th, 2013, 11:11 AM   #3
joe_jeep
welfare wheeler
joe_jeep's Avatar
the track bar frame mount is on the side of the shock mount. the shock mount just bolts on. make sure its uber tight. the mount on my friends bronco came loose a few times. i finally welded it on. make sure it has no play in it. just a random idea?
joe_jeep is online now   Reply With Quote
Old March 7th, 2013, 11:28 AM   #4
twelve
twelve's Avatar
Will do. I'm curious as to wheather the rad arm bushing only being done on one side might be doing it if the trc bar mount is good. Call it a nagging feeling. I'm gonna check, but was wanting to know if it's a possibility. Anyhow thax for the info.
Old March 11th, 2013, 11:20 PM   #5
moparhorse
moparhorse's Avatar
When you say "hop", what does it do exactly?
moparhorse is offline   Reply With Quote
Old March 12th, 2013, 04:18 PM   #6
joe_jeep
welfare wheeler
joe_jeep's Avatar
put a jack under the radius arm right at the mount.
see if it moves at all when you jack it up.
Page generated in 0.18863 seconds with 41 queries
