Home (Basement) Insulation Question - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 7th, 2013, 05:14 AM   #21
Silver Bullet
Livin the American Dream
Silver Bullet's Avatar
Have you tried to pull any yet. If they did not glue it will come off so easy.
Silver Bullet is offline   Reply With Quote
Old March 7th, 2013, 06:37 AM   #22
Suta99
Suta99's Avatar
You Americans are crazy. I've done so much drywall in my life and have never seen or heard of anyone glueing it.
Old March 7th, 2013, 07:38 AM   #23
CHVYPWR
D.I.L.L.I.G.A.F.
CHVYPWR's Avatar
Originally Posted by xj4life View Post
Trying to finish my basement. Previous owners had already partially finished it in that they put up foam board on the block walls, then 2x4 walls, and then dry wall (they did not tape, mud, or finish the walls at all). They did not put anything in the cavity of the wall. To meet code I've gotta get a minimum of R13 so I have to add some form of insulation.
What I'm hoping to find is foam that can be sprayed into my finished walls so that I dont have to pull all the dry wall down. Any one come across a product or company that offers a product/service like this? If not I'll have a fun weekend of pulling down dry wall that was nailed in place
Did you actually pull a permit for this?? If so, WHY?? If not, whos cares about the damn code?!?! Insulate as you see fit and finish it off.
What the out of control building inspecters in this state dont know wont hurt them, or cost you more headache!
Old March 7th, 2013, 07:47 AM   #24
FORD FLARESIDE
Headed to Nationals 2017!
FORD FLARESIDE's Avatar
But it will hurt him when he goes to sell it.
Old March 7th, 2013, 07:50 AM   #25
BigBird
Duck Shootin' Wheelerer!!
BigBird's Avatar
Originally Posted by TJJEEP View Post
Really? All the drywall work I have taken down has had liquid nails and then screws holding. In my limited homeowner experience and a couple friends houses.
Do you not have a plastic vapour barrier between the framing and drywall on exterior walls??? If so does the liquid nails stick to the plastic vapour barrier?? It sounds like a good way to ensure you wouldn't get any screw pop outs from loose drywall, or over tightened screws...
Cheap Thrills Off Road
Old March 7th, 2013, 08:15 AM   #26
xj4life
xj4life's Avatar
yeah i've pulled two boards already and they were only nailed into place
i havent pulled permits but i will be. a - i'm doing most of the work and want it done right and to code, b - i want to be able to claim it as finished sqft so i can get some value back when i go to sell the house. i have to do this regardless so i might as well get some financial benefit. i'm sure my taxes are going to go up but should also be able to get rid of PMI if my assessed value goes up.
i dont plan on doing any plastic vapor barrier, the foam board is going to be my vapor barrier. i was researching it on the internet and the theory i liked is that vapor barrier against the drywall would just keep the moisture trapped inside the wall potentially causing more issues. i've already spoken with an inspector in my town and he's okay with my plans
Page generated in 0.41545 seconds with 40 queries
