*SOLD*2002 Dodge Ram 2500 Cummins Lifted - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 5th, 2013, 03:28 PM   #1
montecarlo33
The Violator
montecarlo33's Avatar
Default *SOLD*2002 Dodge Ram 2500 Cummins Lifted
Currently looking at a house with property forsale so I want to see what intrest my diesel may have. Bought it off here not too long ago.
orginal sales thread.
*SOLD* 2002 Dodge Ram Cummins 4x4 2500 QCSB BDS 6" long arm 37" BFG - Great Lakes 4x4. The largest offroad forum in the Midwest
2002 Dodge Ram 2500 Extended cab short bed cummins. Just over 213,000 miles and runs awesome like it always has, very strong motor with Rotella oil inside. Power windows, locks and rear slider window. 5" BDS Long arm lift, 37" BFG KM2's on 17" mickey thompson rims, only about 5k on lift and tires, professionally installed by unlimited offroad center. Edge attitude programmer also professionally installed, I added a drawstraw V kit and a bigger Holly fuel pump which allows it now to be turned up to any level. Dana 60(non disco)/70 combo, open front, rear TIGHT limited slip. Was a commercial truck and hauled water tank in the bed, looks like it was sold to personal person at 198,000 miles according to carfax. Previous owner claimed not offroad ever, been offroad twice by me. Once for a fall color tour where we crept around the woods, the other time was Thanksgiving at the mounds, but not beat on and 30 dollars worth of car washing right after since I went though a few smaller holes, it was quite capable. Drove home after thanksgiving and its been in my barn in storage ever since(battery tenders and fuel additive for storage) I got it out the other day and it fired right up. Bought a cheap jeep ZJ since my commute to work is only 5 miles. Dont want to sell but it would make getting a house easier for me, not something I planned on for a few more years when i bought this truck.
Bad depending on how picky you are:
-Rear doors are still not functional but I will be fixing now that its starting to warm up, and will be fixed for new owner just needs a lower latch since it has new cables but both are stuck currently.
-Not too much rust, pretty clean for a michigan owned truck all of its life, has holes in front fenders which most of these do, and planned on new fenders which are about 150 a piece. Also some rust starting on the lower part under the doors, again had plans of fixing in spring but very fixable since its early and doors are still rust free, same as when I bought it and not didnt drive in salt this year until yesterday. Tailgate is the only thing with dents, bought it that way but not bad but I would find a clean one if you were painting truck.
- the 3.55 gears need to be changed at some point to 4.56 or 4.88 for towing, but gets between 18-20 mpg the way it is now, just dont use OD for around town only when I get out of town on a good roll, at 55-60 it rolls over 1200rpms in OD. Only time the gearing has been an issue is towing at 70mph its between gears and eather too high or too low so I just towed at 60 and left it in Drive. Both axles are nice and tight, driveshafts I installed new u joints and balljoints were done recent. I put 2 brand new timken front wheel bearings on in Nov at over $350.00 a side for parts only.
- Needs a new transmission but is orginal. Torque converter shudders and as far as I can tell was doing it before I bought it since the trans had shavings when i dropped the pan to inspect after getting it home. Since I got it and still currently will drive and shift ok as long as your just driving not towing with it or applying alot of torque to it(large hills) and doesnt do it at all when the trans is cold which is why I never noticed this when I bought it but I did start to notice it a tad on the way home when I got into the hills on I-75 in west branch. I have someone local that I had a transstar replacement lined up with a 3yr/100,000 mile warranty with all the updates and whatnot, that I can pass along the deal to if intrested, but bottom line this will hold out for a while driving it daily with no load, but needs attention soon. Also just like alot of them, the trans pan is warped and is leaking a tad, threw some gasket maker on it but its dripping again but with a new trans it shouldnt be an issue anymore im told.
- Transfer case needs clocking ring installed to drop the front driveshaft down some since the lift. I have one that I bought, all im missing is the "seal adaptor" which needs to be measured once apart, I was holding onto this until I did the transmission. 4x4 works great but will cause vibrations at 40mph+ currently without the clocking ring but from everything I read that the clocking ring will eliminate this.
- Typical dodge steering, a little loose but all the steering(tierods, links) is nice and tight so I assume its the steering box thats also orginal. Has a steering dampener.
- AC still doesnt work and I did mess with it this summer. Previous owner put a new compressor on and from labels ive read on truck they were hunting down a leak at some point before I got it. I tried to charge the system like the seller suggested and no luck. Had it looked at and its believed to be the evaporator core behind the dash. Not an expensive part but a common one in these trucks. Since the compressor is new, to rebuild the rest of the AC system is cheap to do, its the labor to take apart dash, but my plans was to replace the rest of the system with new and throw in a heater core while dash was up and be done with it. AC isnt a deal breaker for me so I was just waiting till I had extra time/money this summer.
Even though this truck needs a few things, its a great runner and would make a great truck for many years once transmission is replaced, no doubt in my mind. I had plans of making it my tow rig/recovery truck for my jeep and other toys but plans changed since I finally found a house im intrested in. Located in Gaylord, MI and forsale locally.
$10,000 obo NO TRADES.
(989)787-zero zero five seven
montecarlo33 is offline
Old March 6th, 2013, 09:02 AM   #2
montecarlo33
The Violator
Bump for the day.
Old March 7th, 2013, 12:19 PM   #3
montecarlo33
The Violator
Ttt
Old March 8th, 2013, 02:22 PM   #4
SS
Bananarama!
SS's Avatar
As lame as this sounds...
That's my god damned dream truck. Wish I could buy it from you. Can't do a damn thing until my LJ sells.
-Jer
SS is offline
Old March 8th, 2013, 02:36 PM   #5
montecarlo33
The Violator
Doesnt sound lame at all cause thats the same reason I bought it, it is and has been for awhile, my dream diesel truck. I saw it on here, kept looking at it and finally HAD to have it. Honestly as much as I dont want to get rid of it, its a big hurdle that I cant jump over when buying a house with property that I need and want more, Im sick of paying rent and dealing with my current neighbors and want my own barn finally. Im ready to start on a house that I own and can build anyway I want, then worry about toys such as this, right now im trying to go back to basics. There will be other diesels out there for me one day, but this truck would really make someone happy, expecally if you do a few things it needs, it would be perfect. Had plans to really fix this thing up this summer and paint it but my loss is someone's gain, very nice truck with a very strong motor
*Edit - Looks like someone cleaned up my thread today.
Old March 9th, 2013, 12:52 PM   #6
montecarlo33
The Violator
Bump for the day.
Old March 10th, 2013, 03:37 PM   #7
montecarlo33
The Violator
Own one of the few stackless diesels out there left! They are endangered!
Old March 10th, 2013, 04:59 PM   #8
masterbeatty
masterbeatty's Avatar
good lookin truck man
masterbeatty is offline
Old March 10th, 2013, 05:10 PM   #9
bigjay
The Man Myth And Legend
bigjay's Avatar
Location: i can piss on the allegan and barry county line at the same time.. ...
maybe a few pics with the tow mirrors out?.. stacks on stacks
bigjay is offline
Old March 10th, 2013, 07:37 PM   #10
montecarlo33
The Violator
Thanks guys! no stacked on stacked chips and no tow mirror pictures, as i only used them a few times when towing which is weird, right?
Someone just called me from CL and had a offer which was low, but says hes calling back after we spoke for a few so we'll see!
Old March 11th, 2013, 08:47 PM   #11
montecarlo33
The Violator
Ttt
Old March 14th, 2013, 08:35 AM   #12
montecarlo33
The Violator
Ttt
Old March 16th, 2013, 09:23 AM   #13
montecarlo33
The Violator
Lots of tire kickers, no offers yet. Ttt
Old March 17th, 2013, 11:50 AM   #14
montecarlo33
The Violator
Ttt
Also while i appricate the mods cleaning my thread up from comments from others which i addressed, it was not needed in this case, and i wish posts with additional information that i personally post would not be deleted along with it, days later without my knowledge. Thank you.
Old March 18th, 2013, 03:19 PM   #15
montecarlo33
The Violator
Price drop 10,000 obo!
Old March 19th, 2013, 03:49 PM   #16
montecarlo33
The Violator
ttt!
Old March 20th, 2013, 04:40 PM   #17
montecarlo33
The Violator
Bump. Need this gone!
Old March 21st, 2013, 10:24 PM   #18
montecarlo33
The Violator
Hmm lots of lookers no serious offers yet. Ttt
Old March 24th, 2013, 12:39 PM   #19
montecarlo33
The Violator
Sunday bump. Need to sell thats why its listed OR BEST OFFER. Could be a awesome recovery/tow rig to get you and your equipment to the trails or back of out of them, something to still wheel if your rig breaks down during a trip or weekend, or simply a daily driver getting the chores done while still having enough room for the family. Very dependable just needs a little love.
Old March 25th, 2013, 12:29 AM   #20
moparhorse
moparhorse's Avatar
To bad the trans needs work
moparhorse is offline
Page generated in 0.61446 seconds with 84 queries
