14 bolt gear setup pattern - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 4th, 2013, 10:46 PM   #1
19602
Default 14 bolt gear setup pattern
Need to know where to go from this. These are used gears.
19602 is offline   Reply With Quote
Old March 5th, 2013, 10:28 PM   #2
MiNi Beast
MiNi Beast's Avatar
What's your backlash look like?
Old March 5th, 2013, 10:36 PM   #3
19602
Originally Posted by mini beast View Post
what's your backlash look like?
.007
Old March 5th, 2013, 10:45 PM   #4
MiNi Beast
MiNi Beast's Avatar
What's that to the spec? Then add to go down and take away shims to go foward.
Old March 5th, 2013, 10:50 PM   #5
19602
Backlash should be between .003" - .012", with .005"-.008" preferred
Old March 5th, 2013, 10:54 PM   #6
19602
Add shims to the pinion?
don't understand what you mean by down in forward, need a reference point to go off of.
Old March 5th, 2013, 11:00 PM   #7
MiNi Beast
MiNi Beast's Avatar
Need to move the ring gear away from the pinion, more backlash basically.
Old March 5th, 2013, 11:05 PM   #8
19602
Alright. I'll try it tomorrow.
Old March 5th, 2013, 11:07 PM   #9
19602
Thanks by the way.
Old March 6th, 2013, 06:11 AM   #10
19602
Originally Posted by deerebowtie View Post
get more load on the pinion or shove an axle shaft back in and let the tire drag the ground while you roll the gears around. your contact patterns is hard to read
I'll try dragging a tire on the ground. Ive put 50 pounds of torque on the pinion (14 bolt setup "bible" recommends that much) and it just won't leave a good pattern.
Old March 6th, 2013, 06:42 AM   #11
Cool parts peddler
Ironman Offroad's Avatar
Used gear set patterns are always a crap shoot. I would not expect a great pattern and live with good. You did settle for used stuff.
Looks like you need to move the pinion away from the CL (more shim) then readjust your backlash.
Proper bearing preload will usually create a decent impression. I use a box wrench on a ring gear bolt to turn the carrier and let the pinion bearing preload create the load with great success.
I hope this helps.
Old March 9th, 2013, 11:04 AM   #12
19602
Going to try and tackle it again this weekend. I'm assuming I'm going to have to keep shimming it out and adjusting backlash, then checking the pattern.
I would be happy settling for a non-perfect pattern, just trying to make the best out of what i have. Got a really good deal on the front and rear gears, and the right carriers (original was toast on 14 bolt)
Also had machine work done to 14 bolt ring gear and didn't want to risk screwing up a new one.
Old March 9th, 2013, 11:06 AM   #13
19602
Can anyone make a guess on how much more this needs to be shimmed out?
Old March 9th, 2013, 05:27 PM   #14
MiNi Beast
MiNi Beast's Avatar
Are you just winging it or do you have the ideal spec in front of you? There are ideal numbers for you to reference from. Typically you start with that standered number and work either forward or back. I know Randy's ring and pinion has a great book out there all about gears and diffs! I used it when set my gears up.
Old March 10th, 2013, 09:25 PM   #15
moparhorse
moparhorse's Avatar
I would try to shim the pinion away from the carrier .010 or .015 thousandths and re-check it. The best way to setup used gears is to check the pattern and backlash before pulling the gears out to swap into another axle. Most people cant do this because they just have the gears and not the whole alxe
moparhorse is offline   Reply With Quote
Old March 11th, 2013, 04:46 PM   #16
19602
Pulled the axle so i'm going to set up the gears out of the vehicle. Whole process has been a pain in the ass so far. I shimed the pinion out further but i still have to re-adjust backlash and check the pattern Again. Once i get to that ill put up some more pictures.
Looked at randy's, didn't see the book but found a yukon install guide.
I don't have an ideal number or know where to find it.
Old March 11th, 2013, 07:22 PM   #17
Tab
Tab's Avatar
The ideal number charts are for new gears, not used. Get the pattern the best you can, the backlash within reason, and run it.
Old March 11th, 2013, 07:32 PM   #18
bigbchevy
missmrgreenagain
bigbchevy's Avatar
This
H.o.r.e
Old March 11th, 2013, 10:48 PM   #19
moparhorse
moparhorse's Avatar
I had to set the backlash on a old corporate axle, 9'' rear end style and had the backlash a .015 for it to be runnable. Good thing with used gears and 14bolts are that they are cheap
Old March 13th, 2013, 09:00 PM   #20
19602
More pictures.
.0033 pinion shim
.004 backlash
Still looks like shit, but I don't know where to go.
Page generated in 0.49355 seconds with 83 queries
