Stuck pinion - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 30th, 2006, 09:43 AM   #1
itselliott
itselliott's Avatar
Default Stuck pinion
Axle is a Mod-20, stripped down to holding ONLY the pinion.
That's the problem....The Pinion.......doesn't want to come out.
I've soaked the contact area between the bearing and shaft for days. Have used an air hammer with a blunt point on the shaft.
My next thought is to take it to work and put it in a hydraulic press..........pretty sure this will move the pinion, the concern is that I may end up cracking the housing in the process.
Any ideas?
Old October 30th, 2006, 09:55 AM   #2
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
brass drift and a BFH... I use the air hammer and push like hell. It takes a bit put the vibrtation does work...
Old October 30th, 2006, 01:05 PM   #3
fr3db3ar
KISS MY AVATAR
fr3db3ar's Avatar
If you never need the pinion again.......Beat the fukc out of it :tonka:
Page generated in 0.12994 seconds with 32 queries
