Looking for input-trans and tcase options - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 4th, 2013, 09:15 PM   #1
03tjsport
Red Dragons!
03tjsport's Avatar
Default Looking for input-trans and tcase options
Looking to swap a 5.0 from a 97 explorer into a tj. If I use the explorer trans,what tcase bolts to it? It was full time awd before. Or go with a c4 or c6? Thinking it will be used for dd/trail use when finished. I want to do a 2" lift and highfender conversion. Thanks.
03tjsport is offline   Reply With Quote
Old March 4th, 2013, 09:25 PM   #2
Its the same basic trans as the aod and aode found in broncos and f150s. I replaced my awd case with a 4406 from a 97-03 f150. But 205s, 1356s etc will bolt up. I chose the 4406 because it was lighter and offered a much better low range then a 205, and it was narrow enough to fit in the frame rails.
My wife and i both have 98 explorers with 5.0Ls and i converted both using the 4406.
Old March 5th, 2013, 05:58 AM   #3
03tjsport
Red Dragons!
03tjsport's Avatar
Thanks. I will check into those. I would like manual shifting and the ability to install a sye.
Old March 5th, 2013, 06:09 AM   #4
bigbchevy
missmrgreenagain
bigbchevy's Avatar
im running a c6 / 205 in my tj
H.o.r.e
Old March 5th, 2013, 06:33 AM   #5
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
I have aod/203/205 in my jeep but the case cheapthrills suggested or a np208 would work and certain models had a fixed rear output from the factory so no sye required
Old March 5th, 2013, 07:28 AM   #6
03tjsport
Red Dragons!
03tjsport's Avatar
Yeah. I just saw a 1356 on here that looks like it would work.
Page generated in 0.18544 seconds with 41 queries
