97 1500 throwing code P0740 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 2nd, 2013, 04:48 PM   #1
w5778
Slave to my trucks
Default 97 1500 throwing code P0740
my 97 1500 is throwing a code for torque converter clutch circuit malfunction can anyone shed some light on what this is to me. how serious is it if driven and how hard is it to fix thank you will
w5778 is offline   Reply With Quote
Old March 4th, 2013, 12:26 PM   #2
w5778
Slave to my trucks
Old March 7th, 2013, 07:22 PM   #3
w5778
Slave to my trucks
ttt
Old March 7th, 2013, 07:30 PM   #4
kkodet
kkodet's Avatar
Might help to mention Chevy or Dodge, Truck or Van.
Old March 7th, 2013, 07:31 PM   #5
w5778
Slave to my trucks
Assuming its in the dodge forum i would say its a dodge and assume 1500 would mean truck
Old March 7th, 2013, 07:33 PM   #6
Toyfish
Toyfish's Avatar
They made 1500 vans to but anyways it soulds lile it should shift fine but prolly wont go into lock up so u should be fine but without the tc locking up it may heat up ur trans
Sent from my DROID X2 using Tapatalk 2
Old March 7th, 2013, 07:40 PM   #7
w5778
Slave to my trucks
so it should be fine as long as i dnt go on any road trips as long as the rpms are good at shift points until i can get it fixed? any idea of the cost of parts and if its doable by a backyard mechanic? thanks. and its a 97 single short sport with 318 unsure 0f trans and transfer.
Old March 7th, 2013, 07:42 PM   #8
Toyfish
Toyfish's Avatar
First thing to do is drop the pan and check for broken wires on the torque converter solenoid but just watch the shift points if they r ok it ahould be ok to drive
Old March 7th, 2013, 07:44 PM   #9
w5778
Slave to my trucks
yea no problems shifting at all, and on a level of easy and dnt even try what would you say it is?
Old March 7th, 2013, 08:21 PM   #10
kkodet
kkodet's Avatar
From tapatalk it doesn't come up as being in the Dodge specific forum.
Old March 7th, 2013, 08:25 PM   #11
Toyfish
Toyfish's Avatar
Dropping the trans pans is very easy now changing the tc solenoid i have no idea how hard that is but if u google it u should be able to figure out which wires r for the tc solenoid and u can check them for beaks
Old March 8th, 2013, 01:30 PM   #12
w5778
Slave to my trucks
alright thanks
Page generated in 0.23234 seconds with 59 queries
