anyone heard of RE audio? - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 3rd, 2013, 09:31 PM   #21
drew454u
drew454u's Avatar
Back when they were American made they did.
drew454u is offline   Reply With Quote
Old March 3rd, 2013, 10:31 PM   #22
Wehan
Wehan's Avatar
Funny how they are made overseas now and twice the cost they used to be.
Sent from my Galaxy S3 using tapatalk 2
Wehan is offline   Reply With Quote
Old March 4th, 2013, 11:17 AM   #23
drew454u
drew454u's Avatar
That's true, the old ones are very underrated also. Especially since there rated at 12 volts instead of the commonly used 14.4
Old March 4th, 2013, 12:27 PM   #24
barry1me
Just another day
barry1me's Avatar
looks like industry standard now is 14.4 volts. I cant believe how overpriced most of these car audio stores are. Unreal, I see how the car audio business is failing when its over double the price as online.
barry1me is offline   Reply With Quote
Old March 4th, 2013, 05:40 PM   #25
barry1me
Just another day
barry1me's Avatar
Ok guys Im looking for some insight. Here are my three sub options I have it down to:
RE audio SXX 12 $240 range
Wetsounds XXX 12 $700 range (im sure I can do better)
Alpine SWR 12 Type R $180 range
For Amps Im down to a Syn 1 $600 range, a Rockford Fostgate prime 1200x1 $250 range or a Hifonics Brutus BRX 2100 for $300 range.
Im not to overly concerned with water damage as none of these should see much moisture or water. What does everyone think when you compare the specs?
Old March 4th, 2013, 06:35 PM   #26
Wehan
Wehan's Avatar
Mtx makes reasonable marine components.
Old March 4th, 2013, 06:44 PM   #27
stereoguy
2jz NO SH*T!
stereoguy's Avatar
If you are trying to do this sub in a marine environment , I would stick to a marine sub. A marine sub is made for the extreme environment of a boat and for the inherently weird sized enclosures that they have. All of the subs except for the wet sounds one are car audio subs. If you are going to take a spot on your boat, lets say in a lift off area of a seat . And build a enclosure that is the correct volume and tuned with a port . It has to be completely sealed except for the port in the box, Then you will have to integrate this enclosure in the area you have with fiberglass and seal it in perfectly . If you are willing to do this a car sub will be fine . If not then go with a real marine sub. This is how you mount a marine sub. You find a compartment and cut a hole then screw a marine sub in wire it up and rock on! The reason a marine sub is better has almost nothing to do with the water . It works better because they know most people are just going to put them in a seat compartment and not calculate the shit out of the actual volume of a odd area and try to make it airtight. Alpine makes a 10" SWR M100 sub that a retard could install and have amazing results with. It costs around 230.00 so it is not expensive . Trust me , if you are doing the work yourself you are going to like just cut a hole mount it and rock . It's theil small parameters are made like the old free air subs ,so it will take a huge cabinet or smaller one and it doesn't have to be airtight . I carry Digital Designs subs and have put them on a boat and I can tell you how much work it takes for a pro to do it right . I call it my bend over, if you have to ask you can't afford it price list By the way a Digital Designs 9500 12 starts at 900 without any options , the Z series are 2200 each in a 12. I would go the Alpine SWR M100 NOT the Type R Or the RE subs. If you want it really loud do multiples of the 10 ,yopu will be very happy I hope this helps you out.
stereoguy is offline   Reply With Quote
Old March 5th, 2013, 11:27 AM   #28
disorder xj
Happy,happy,joy,joy
disorder xj's Avatar
alpine type r 2 ohm dvc . I have some p.o.s crunch amp running it at about 500 rms per coil.
disorder xj is offline   Reply With Quote
Old March 5th, 2013, 05:59 PM   #29
bdd1469
bdd
bdd1469's Avatar
Stereo guy has some very good advice.
It's not so much what sub you buy, it matters much more that the speaker and box it is in are made for each other.
Page generated in 0.33576 seconds with 49 queries
