what transmissions are interchangeable for a 2001 Ram 2500 automatic? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 2nd, 2013, 12:03 AM   #1
TJ SKWIG
Professional Dumbass
TJ SKWIG's Avatar
Default what transmissions are interchangeable for a 2001 Ram 2500 automatic?
i have a 2001 dodge ram 2500 2wd with 46re automatic transmission.. im wondering what year/ model vehicles i can swap transmissions with and does it matter if its 4x4? can i swap some parts from the 2wd transmission over to the 4wd trans to make it work in my truck..??
TJ SKWIG is offline   Reply With Quote
Old March 4th, 2013, 08:07 AM   #2
88yjproject
Not sure on years. But you would have to disassemble both transmissions and swap the output shafts and rear extension housings.
88yjproject is offline   Reply With Quote
Old March 4th, 2013, 08:52 AM   #3
TJ SKWIG
TJ SKWIG's Avatar
Easily done or not? It's kind of hard trying to locate a 2wd transmission for these trucks
Old March 12th, 2013, 12:09 AM   #4
moparhorse
moparhorse's Avatar
Its easy if a trans guy does it, like me. I do have a 97 trans but it dont have the valve body. 94-98.5 transmissions are hydraulic controlled. 98.5 and up are electronic ones. If you find a hydraulic one, you can swap the valvebody harness from yours, your tailhousing, governer tubes and plug off the governer feed holes in the rear support housing and it will work. Whats wrong with it?
moparhorse is offline   Reply With Quote
Page generated in 0.30107 seconds with 35 queries
