4 link bracket help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 1st, 2013, 12:20 PM   #1
jessezipper
Default 4 link bracket help
well my driverside link mount finally sheered off my axle (oem) who sells a good replacement?? its a stock 95 zj, no lift, nothing special.... I seen rustys, just wondering if theres other options....
jessezipper is offline   Reply With Quote
Old March 1st, 2013, 01:18 PM   #2
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Just the link mount?
http://www.artecindustries.com/Lower...air_p_252.html
Old March 1st, 2013, 02:40 PM   #3
jessezipper
Yea the one that's on the axle , the link is fine
Old March 1st, 2013, 02:50 PM   #4
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Will the link I showed work, or are you looking for the integrated spring pad and shock mount to?
Old March 1st, 2013, 02:54 PM   #5
I don't know if you are the best person to give advice for axle link brackets.
Old March 1st, 2013, 03:01 PM   #6
jessezipper
Yea that will work but what's the difference between that and ....
http://www.ironrockoffroad.com/Merch...tegory_Code=UP
Old March 1st, 2013, 04:16 PM   #7
Dylan
Dylan's Avatar
what you are looking for is this. It has the cam adjuster U shape thing on it.
http://csloffroad.com/xjfrontaxlelow...hfabworks.aspx
Old March 1st, 2013, 04:29 PM   #8
jessezipper
Is the cam adjuster part needed? It's the only one
So far that I've seen with it on there.. No lift and pretty much stock..
Old March 1st, 2013, 06:44 PM   #9
Dylan
Dylan's Avatar
if you want any type of caster adjustment you will need it. If you don't care about caster adjustment than no, its not needed (or if you have adjustable control arms)
Page generated in 0.41040 seconds with 50 queries
