air tank - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 25th, 2013, 10:25 PM   #1
Shortbus
W.H.O.R.E.-a-licious
Shortbus's Avatar
Default air tank
located in North Muskegon
$65 obo
The tank is 31" tall, from bottom to the top of the fitting and 7.5" in diameter, since I don't know the thickness of the tank walls, I can assume the volume is between 3 & 4 gallons.
It was originally made for planes & boats (this was from a plane) but can no longer be used for that purpose, it is out of date.
It shouldn't be used for it's rated pressure anymore, which is 1,850psi, but can easily handle the normal pressures a compressor can put out.
It weights 13#'s.
The fitting on top is a 3/4" NPT.
Thanks, Jeff
Shortbus is offline   Reply With Quote
Old February 26th, 2013, 03:19 AM   #2
crazygrady127
crazygrady127's Avatar
Wish you were closer !! Free bump
Tear It Up - Fix It - And Do It Again
crazygrady127 is offline   Reply With Quote
Old February 26th, 2013, 08:18 PM   #3
Shortbus
Shortbus's Avatar
I'm happy to ship it to you!
OR
If I still have it in a couple weeks, I have a friend that will be stopping over here for the weekend and then back to Walled Lake. Don't know if that would work for you.
Page generated in 0.47955 seconds with 32 queries
