CAD Delete Pros or Cons - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 25th, 2013, 06:31 AM   #1
Fidget56
Fidget56's Avatar
Default CAD Delete Pros or Cons
I have a 99 ram 2500 Im looking at doing the CAD Delete for the four wheel drive system.
Any pros or cons?
Thanks
Fidget56 is offline   Reply With Quote
Old February 25th, 2013, 06:36 AM   #2
Wehan
Wehan's Avatar
Potential front driveshaft vibrations as it will now be spinning all the time 2x or 4x. So if it's like my yj with a saggy shaft you will need a new one.
Sent from my Galaxy S3 using tapatalk 2
Wehan is offline   Reply With Quote
Old February 25th, 2013, 07:18 AM   #3
masterbeatty
masterbeatty's Avatar
Id like to know as well, i want to delete myne as well
Old February 25th, 2013, 07:56 AM   #4
snocross2xtremes
snocross2xtremes's Avatar
I deleted mine on my 99. And never had vib problem. Only down side was 1 mph drop. My front shaft did need to be rebuilt once not sure it was just age or that it was spinning all the time.
Old February 25th, 2013, 08:50 AM   #5
Fidget56
Fidget56's Avatar
Joe what CAD delete kit and where did you get it from?
Old February 25th, 2013, 09:37 AM   #6
XXXJ
Desert Rat
XXXJ's Avatar
My 02 ram has no cad. I have no issues.
Front drive rebuilt an balance @ 180k.
I want to do the hub kit soon.
Old February 25th, 2013, 10:09 AM   #7
snocross2xtremes
I actually just slid the collar over and welded splines in few spots so it couldn't slid over but then you could still remove the shaft
Old March 11th, 2013, 11:14 PM   #8
moparhorse
moparhorse's Avatar
Chrysler quit doing the CAD in 2002 because of the bearing and seal problems where the inner cad axle rides. If you front shaft is vibrating, then you need to fix it. Driving it down the road in 2wd isenst that bad on stuff unless its REALLY vibrating. Now when its in 4wd and the front shaft is under a load and vibrating at the same time, thats when pinion bearings and your t-case output go to shit. I hate the CAD axles!
moparhorse is offline   Reply With Quote
Old July 31st, 2013, 06:31 AM   #9
TheDodgeGuy
PR MTU 4X4
TheDodgeGuy's Avatar
Best bet is to replace the vacuum setup on the cad with a cable pull design. Unless you get a free spin kit or have a dana 60 from that you can convert to lockable hubs your not going to want to completely get rid of the cad.
TheDodgeGuy is offline   Reply With Quote
Old August 2nd, 2013, 03:55 PM   #10
montecarlo33
The Violator
montecarlo33's Avatar
x2 my 01 didn't eather. front shaft got rebuilt at 215k but it had a lot to do with the lift and no transfercase clocking. The hub kit was the only thing I wish it had as well but the CAD being locked all the time should bother you at all.
Old August 2nd, 2013, 05:33 PM   #11
joe_jeep
welfare wheeler
joe_jeep's Avatar
the hub freespin kit is on sale used on here from hamsmotorsport.
his truck was never wheeled, the kit should be in great shape.
Old June 9th, 2014, 02:35 PM   #12
GreenSound
GreenSound's Avatar
Another thing to consider is without the disconnect, the transfer case chain will be spining all the time, churning the fluid in the tcase, reducing fluid service interval drastically.
GreenSound is offline   Reply With Quote
Page generated in 0.31807 seconds with 59 queries
