Ranger SAS Question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 24th, 2013, 09:55 PM   #1
chasetheface123
chasetheface123's Avatar
Default Ranger SAS Question
What springs are you guys running? I've got a set of superflex bronco springs and they are stiff as fawk. Xj coils work well? Looking for ~6" lift springs. Or, what spring rate works well. I would much rather have too soft than too firm.
chasetheface123 is offline   Reply With Quote
Old February 24th, 2013, 10:06 PM   #2
Toyfish
Toyfish's Avatar
I know wadey used xj lift springs on his blazer sas so they should work well for your ranger too
Toyfish is online now   Reply With Quote
Old February 24th, 2013, 10:24 PM   #3
koochman450r
koochman450r's Avatar
I used xj 6.5 super flex coils on mine. They dont fit the ranger upper buckets though so you have to modify them. Just got done with a ranger SAS.
you won this battle.
Old February 24th, 2013, 10:27 PM   #4
chasetheface123
Don't fit as in too small or too large? I made buckets for mine..
Old February 25th, 2013, 07:18 AM   #5
koochman450r
The little tabs that go into the ranger coil don't fit into the xj coils. I beat them flat and welded a .25 thick circle on the bucket then a 4" piece of 2.5"od tube to go into coil.
Old March 3rd, 2013, 02:54 PM   #6
gear_grinder
maybe zj coils? i think zj jeeps match the weight of a ranger a little bit better
gear_grinder is offline   Reply With Quote
Old March 6th, 2013, 02:39 AM   #7
deathbypsi
Brian R.
deathbypsi's Avatar
On my Bronco2 I used Skyjacker Softride 6" jeep xj coils. Rode soft and flexed a bunch
Old March 16th, 2013, 08:52 PM   #8
trogdor the burninator
Insert Comment Here.
trogdor the burninator's Avatar
Send a message via AIM to trogdor the burninator Send a message via MSN to trogdor the burninator
XJ coils on my exploder.
Just another disgruntled OIF vet.
trogdor the burninator is offline   Reply With Quote
Old June 16th, 2013, 10:56 PM   #9
NewGuy
So true cause they did the same on my explorer!!! LOL
NewGuy is offline   Reply With Quote
Page generated in 0.41313 seconds with 50 queries
