"The other Woman" LJ - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 24th, 2013, 05:24 PM   #1
robbietap
Default "The other Woman" LJ
Picked up an 05' LJ from Davey's Jeeps, was smushed pretty good in the front right. Still trying to find some of the earliest photos I have.
Plans, comp cut, 07' dana 60 f/ 14 r, stock motor (for now), stock transmission, 231/300 case, build a cage, build tube fenders, highline, bumpers/ winch mnt., 4-link front and rear, full hydro...
Bare with me, photobucket virgin, might need some help uploading pics.
robbietap is offline   Reply With Quote
Old February 24th, 2013, 05:27 PM   #2
robbietap
Old February 24th, 2013, 05:32 PM   #3
robbietap
Narrowed the 60 a bit, had Rock Solid cut down my shaft and drill my bearings for standard
bolt pattern.
Old February 24th, 2013, 05:36 PM   #4
robbietap
Belly and lower/upper control arm mounts rear.
Old February 24th, 2013, 05:40 PM   #5
robbietap
Cut out the tin rear crossmember that the stock bumper bolts through and replaced it with a 3/16 with tow points through to the frame, body mounts through the top of new piece as well.
Old February 24th, 2013, 06:59 PM   #6
threeEs99
threeEs99's Avatar
Have always wanted an LJ but never had the extra $$ for one. Really looking forward to this build.
threeEs99 is offline   Reply With Quote
Old February 25th, 2013, 08:32 AM   #7
robbietap
Picked it up pretty cheap as a salvage, most of the damage was fender, grill, hood front axle, things that were either going away or replaced easily.
Old February 25th, 2013, 08:45 AM   #8
hawkscj5
Skinny Pedal Crawler
hawkscj5's Avatar
x2 love the name too!
hawkscj5 is offline   Reply With Quote
Old February 25th, 2013, 09:31 AM   #9
green50gt
Got rocks?
green50gt's Avatar
Cool build. Curious if you found more wrong with it than what was originally described or not?
I heart Jeeps
green50gt is offline   Reply With Quote
Old February 25th, 2013, 01:35 PM   #10
robbietap
@green50gt
Not really, the description was front pass hit, doesn't steer. Davey does a good job getting enough pics that you can pretty well see what you have. The fist pic I have here is after a bunch of work, still looking for some of the "as is" pics from when I picked it up. The grill was pushed into the fan, right fender was gone, pass side door didn't shut and match the a pillar as the tub had some damage and was pushed in a little around the battery box. Front upper and lower control arms were pretzels, bumper bent, steering box shaft snapped off, broken windsheild, Etc... Borrowed a lot of parts to get through inspection, then began cutting. Most of what was broken or bent/damaged was going by-by through the build anyways.
Old February 25th, 2013, 01:44 PM   #11
green50gt
Got rocks?
green50gt's Avatar
Gotcha, just curious. I have had several not so great experiences with them, however I will take some blame as I have them shipped back as opposed to physically looking them over myself.
Back to the build.. What type and size tires are you planning on running?
I heart Jeeps
Old February 25th, 2013, 01:50 PM   #12
robbietap
38-39" radial mud terrains, not sure on brand yet. Had Bias Irok 39.5's on a buggy and loved em, but thinking something more street friendly.
Old March 10th, 2013, 11:58 AM   #13
robbietap
Got a little work done on the front end.
Old March 11th, 2013, 01:30 AM   #14
OnlyInMyXJ22
No Money = No Fun
OnlyInMyXJ22's Avatar
Looks good!
*2007 Rubicon
*2006 Duramax
*2005 CRD
Old March 26th, 2013, 08:31 PM   #15
VIGILANTE
Done yet ?
VIGILANTE is offline   Reply With Quote
Old April 4th, 2013, 07:56 PM   #16
robbietap
Closer...
Old April 4th, 2013, 08:17 PM   #17
robbietap
Upper rear brackets complete.
Front bumper/winch plate complete.
And tranny/oil pan skid complete. Now time for some control arms and air shocks and its a Roller!!
Those bolts will be counter sunk by the way...
Old April 4th, 2013, 09:18 PM   #18
kmanxj5011
kmanxj5011's Avatar
Looks awesome! Can't wait to see it done. Have to finish by next winter so you can help me build my cage! ;)
kmanxj5011 is offline   Reply With Quote
Old April 4th, 2013, 09:52 PM   #19
robbietap
We can start on your cage in July, as I will be done!
Old April 4th, 2013, 10:20 PM   #20
kmanxj5011
kmanxj5011's Avatar
OK. I am going to slowly start buying tube. We'll talk.
Page generated in 3.70638 seconds with 83 queries
