Jeep Cherokee Dana 44 Axles****SOLD**** - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 24th, 2013, 03:09 PM   #1
dmcjeep
dmcjeep's Avatar
Default Jeep Cherokee Dana 44 Axles****SOLD****
Removed from a 75 Cherokee. They have some kind of lockers. No idea what kind also still have to check gear ratio. I suspect 3:54 gears. Passenger drop front. $250 for the pair or $150 each. Missing one of the hub assemblys. The guy that delivered them says he has the hub etc but forgot to bring it along. Hopefully I will be getting it from him but right now it is not there. Also has a drop pit man arm still attached.
dmcjeep is offline
Old February 24th, 2013, 03:41 PM   #2
Wramblerguy
Wramblerguy's Avatar
When you check ratio could you also confirm locker
3rd generation jeeper
Wramblerguy is offline
Old February 24th, 2013, 04:01 PM   #3
Bo's Cj 7
Bo's Cj 7's Avatar
Are these 5 or 6 lug
Bo's Cj 7 is offline
Old February 24th, 2013, 05:44 PM   #4
dmcjeep
dmcjeep's Avatar
6 lug
dmcjeep is offline
Old February 24th, 2013, 07:07 PM   #5
I'd be curious also what you find inside, if they have lockers, LSDs, welded, etc..
Haggar is offline
Old February 24th, 2013, 07:43 PM   #6
pitbull2332
pitbull2332's Avatar
Flat top knuckle?
pitbull2332 is offline
Old February 24th, 2013, 09:20 PM   #7
newdodge
jeep life
newdodge's Avatar
It is called a vacuum Locker my buddy 75 J 10 truck has the same system the motor crates vacuum activate the transfer case and lock the front axle in
newdodge is offline
Old February 24th, 2013, 11:31 PM   #8
dmcjeep
dmcjeep's Avatar
It is NOT a vacuum locker. The vacuum switch does not have anything to do with the axles. It has to do with the t-case only. It is part of the qudra trac system. I would assume the axle lockers are some sort of "lunch box locker" or something on that order. I should know more tomorrow as I plan on opening them up to see what is in there.
dmcjeep is offline
Old February 25th, 2013, 07:06 AM   #9
newdodge
jeep life
newdodge's Avatar
Well you should have them open in the first place before you post this for sale so people wouldn't have to ask questions
newdodge is offline
Old February 25th, 2013, 07:10 AM   #10
curbdog17
Mini Van
curbdog17's Avatar
don't act like an asshat because someone had to correct you.
curbdog17 is offline
Old February 25th, 2013, 07:27 AM   #11
silveradoboy
Sam Brown
silveradoboy's Avatar
x2
silveradoboy is offline
Page generated in 0.21251 seconds with 56 queries
