best way to remove broken exhaust manifold bolts - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 23rd, 2013, 03:51 PM   #1
scare-crow
the eskimo bro
scare-crow's Avatar
Send a message via AIM to scare-crow
Default best way to remove broken exhaust manifold bolts
Yup I did it. I broke them all. What is the best way to get them out?
scare-crow is offline   Reply With Quote
Old February 23rd, 2013, 03:52 PM   #2
application?
Old February 23rd, 2013, 03:55 PM   #3
scare-crow
the eskimo bro
scare-crow's Avatar
Amc 360
Old February 23rd, 2013, 04:03 PM   #4
Bishop
Bishop's Avatar
I prefer to weld a nut to my broken studs.
The heat/welding current seems to loosen broken bolts real nice like.
Old February 23rd, 2013, 04:04 PM   #5
scare-crow
the eskimo bro
scare-crow's Avatar
that would help if i had a welder -.-
Old February 23rd, 2013, 04:15 PM   #6
Bishop
Bishop's Avatar
Option #2, go buy a welder.
Need more info. Are they broke flush? Is part of the stud sticking out to where you can get a hold on it?
Old February 23rd, 2013, 04:19 PM   #7
scare-crow
the eskimo bro
scare-crow's Avatar
there is about 1/4'' of each one sticking out.
Old February 23rd, 2013, 04:19 PM   #8
Bishop
Bishop's Avatar
If you can get vice grips on them I would heat the head with a torch, the stud should back out pretty easy.
If not you could try easy outs. But I hate using them, never had much luck.
Old February 23rd, 2013, 04:21 PM   #9
scare-crow
the eskimo bro
scare-crow's Avatar
I'll give it a shot
Old February 23rd, 2013, 04:24 PM   #10
pitbull2332
pitbull2332's Avatar
Is the manifold on the engine? IF it is take it off and try and grab what is left of the stud with vice grips. Heat with a torch and melt some candle wax in the threads. Seems to work good. I have had luck with this a few times.
pitbull2332 is offline   Reply With Quote
Old February 23rd, 2013, 04:24 PM   #11
hondadirtracer
Skymaster
hondadirtracer's Avatar
I have gone through this twice now; once on a 4.3l chevy and once on a Bronco with a 351w. Both times I ended up having to center punch the stud and drill them out starting with a small bit and working my way up to the size I needed. Then I tapped the hole and put in a new stud.
hondadirtracer is offline   Reply With Quote
Old February 23rd, 2013, 04:26 PM   #12
Bishop
Bishop's Avatar
Just be careful turning the stud. I usually lightly tighten and loosen the bolt until you can feel it turning. With the heat the bolts will snap off a little easier. But just work it back and fourth and you shouldn't have any problems. Heat is amazing.
Old February 23rd, 2013, 04:31 PM   #13
Bishop
Bishop's Avatar
Never used candle wax. But we used to use toilet bowl ring wax stuff and that worked like nothing else I have ever come across. I would imagine the candle wax works very similar. The heat just sucks the wax right into the threads and it doesn't really burn off or evaporate like wd40 or PB blaster would on heat.
Old February 23rd, 2013, 05:59 PM   #14
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
Mix acetone and ATF 50/50 and use that as a penetrating oil.
Old February 23rd, 2013, 06:06 PM   #15
TJ/WILLYS
TJ/WILLYS's Avatar
Heat them up,melt bee's wax around them and use bolt extractors.
TJ/WILLYS is offline   Reply With Quote
Old February 23rd, 2013, 06:25 PM   #16
wave_crusher
I'll Direc your TV
wave_crusher's Avatar
x (alot) on using heat and wax. Works wonders
Old February 23rd, 2013, 06:30 PM   #17
capone
capone's Avatar
X2
This works great.
capone is online now   Reply With Quote
Old February 23rd, 2013, 06:40 PM   #18
rick1974
every one here is right but would have to agree with bishop the most because all methods mentioned are tried and true and my experince agrees easy outs are not so easy
rick1974 is offline   Reply With Quote
Old February 23rd, 2013, 06:54 PM   #19
davidkassie
davidkassie's Avatar
I have had decent luck by drilling a relief hole in the center. Heat the hole area hot hot. Take cold water and cool it as quickly as possible. Wax works real good as well.. good luck
davidkassie is offline   Reply With Quote
Old February 23rd, 2013, 07:07 PM   #20
scare-crow
the eskimo bro
scare-crow's Avatar
well i managed to break them off deeper into the head... Turns out they use hollow bolts. looks like my job got easier
Page generated in 0.36857 seconds with 83 queries
