Tranny question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 29th, 2006, 08:35 PM   #1
ChevyGirl
ChevyGirl's Avatar
Default Tranny question
Will a tranny for a small block 350 bolt up to a 2.8L GM motor?
ChevyGirl is offline   Reply With Quote
Old October 29th, 2006, 08:46 PM   #2
greenmeanie
greenmeanie's Avatar
i think they have different bellhousings; if you have the 700r4 that is.
greenmeanie is offline   Reply With Quote
Old October 29th, 2006, 09:46 PM   #3
ChevyGirl
ChevyGirl's Avatar
I have a cherokee with a 2.8L in it, the trans that is with it rite now is a TF904 But it is shot i need to find a new one im just tryin to find out what tranny will work wiht that motor.
Old October 29th, 2006, 10:28 PM   #4
No, they have a different bellhousing pattern.
You can swap in a Chevy 2.8, 3.1, 3.4, 3.5, 3.6, 3.8(from a camaro), 3.9, 4.6 northstar, etc.
Old November 1st, 2006, 02:36 PM   #5
ChevyGirl
ChevyGirl's Avatar
alright so what transmissions will work?
Old November 1st, 2006, 04:06 PM   #6
This is a horribly vague question..
What motor do you want to use?
what type of transmission are you looking for (i.e auto, manual 4 speed, 5 speed, etc)?
what vehicle are you putting it into?
what transfer case do you want to use?
Old November 1st, 2006, 04:21 PM   #7
deuce228
Redneck Poser
deuce228's Avatar
Torque Flite 904 is a 3spd Chrysler from the searches I did. Also looks like she has a cherokee, now I am not sure if its a FSJ or an XJ or whatever. I assume XJ because of the curb weight vs HP from the 2.8 would be a joke if in an FSJ.
Old November 1st, 2006, 05:24 PM   #8
SS
Bananarama!
SS's Avatar
You overthought the question (and missed basic information in the original post).
She wants to know which transmissions will bolt up to her 2.8L because the trans that is in it now is junk.
-Jer
Old November 1st, 2006, 05:54 PM   #9
Quagmire
I can has layinframe
Send a message via Yahoo to Quagmire
small bellhousing 700R4 or another 904
Google first.....ask questions later
Actually, the new rule of thumb is you should make your tires bulge slightly more then skooterbuilt when he's wearing his tight ladies pants
Quagmire is offline   Reply With Quote
Old November 1st, 2006, 08:14 PM   #10
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
correct... and why not rebuild the one that is in there. Have the trans pulled and I will rebuild it for you.
Old November 1st, 2006, 10:54 PM   #11
ChevyGirl
ChevyGirl's Avatar
How much would u want to rebuild it Killer B? i am not 100% sure if it is junk yet i gotta check the filter, and the fluid level. i just bought the jeep on sunday and i havent got it running yet cause ive been workin and everything it needs a new battery and i got the ignition stuck, so i cant even turn the key now so i dk if the tranny moves at all or not.
Old November 1st, 2006, 11:36 PM   #12
CHVYPWR
D.I.L.L.I.G.A.F.
CHVYPWR's Avatar
Do your self a favor and get a trans and T-case from a 2.8 powered S-10. The 904 for 2.8's is expensive (price the torque converter, it'll scare you). The S-10 2.8 700R4 will give you over drive and be cheaper to upgrade.
Old November 1st, 2006, 11:46 PM   #13
ChevyGirl
ChevyGirl's Avatar
thnx maybe ill look into that.
Page generated in 0.23531 seconds with 62 queries
