318 using lots of oil? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 29th, 2006, 08:02 PM   #1
71jeepster
Glad I'm not Gay J. Hall!
71jeepster's Avatar
Send a message via Yahoo to 71jeepster
Default 318 using lots of oil?
I have a 97 Ram with a 318, I don't know what the deal is but it uses a quart of oil every 800 to 1000 miles!! It has 150k miles but still runs strong! Just uses oil like crazy!! Has anyone else had this problem, or have any idea what it could be?
71jeepster is offline   Reply With Quote
Old October 29th, 2006, 11:49 PM   #2
noodles
give 'er sh*t ay?
noodles's Avatar
I have heard of the plenum gasket leaking, its under the intake man, and that will cause it to eat oil. I belive I have the same problem going on just havent checked it out..( least im hoping) anyway, take off the air cleaner and look down inside the throttle body and if its all oil that most likely is your probelm ( so ive been told)
Old October 30th, 2006, 06:58 AM   #3
71jeepster
71jeepster's Avatar
there is another gasket under the intake? i didn't know that, i'll have to check that out
Old October 30th, 2006, 07:02 AM   #4
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
I dunno about plenum gaskets, but i have seen the engine sludge up enough to plug the oil return holes in the heads with high miles. after the return holes plug the valve stems are submerged in oil and can't help but burn it. I would start there first.
Yetti
Old October 30th, 2006, 07:05 AM   #5
71jeepster
71jeepster's Avatar
yeah, lot easier to pop the valve covers off an check that first
Old October 30th, 2006, 09:10 AM   #6
84Scrambler
Look down thru the throttle body. If it is wet/oily in there, your plenum gasket is shot. This is extremely common for the 318/360 Magnum motors. There are basically 3 options. You can replace the gasket with a stock replacement that will eventually go bad again, replace the gasket and the thin sheetmetal plate that bolts to the underside of the beerkeg style intake, or upgrade to a Mopar single plane intake that doesn't have a seperate plenum/gasket. Those are ranked from cheapest to more expensive. No matter what you do, you need to pull the intake off to reseal everything.
Old October 30th, 2006, 02:57 PM   #7
dodgegirl
dodgegirl's Avatar
I have a 98 ram and that is exactly what my problem was. It is a known problem that they will acknowledge but chrysler will not fix it. Mine started using oil just after the warranty was up on it. Of course, then I didn't know what the problem was and didn't get any answers that made sense when I took it anywhere locally. I finally started asking on the internet and got my answer right away. Pulled the intake and there was pretty much no gasket left. Replaced it with a new one and my truck runs better now with over 100,000 miles on it than it did when it had 40,000 miles.
dodgegirl is offline   Reply With Quote
Old October 30th, 2006, 03:48 PM   #8
DodgeitRamit
DodgeitRamit's Avatar
Yeah been there done that twice. It definitely cause comsumption of a lot of oil, and some smoke here and there. Yeah you'll get better gas mileage and it will run much better and smoother
DodgeitRamit is offline   Reply With Quote
Old October 30th, 2006, 03:56 PM   #9
user name
keep your stick onthe ice
user name's Avatar
lower intake gaskets are really common. if they go bad you should get a slight vacuum in the crank case. take all the hoses pcv and breather out cover all but one hole and see if there is any vacuum at the one you didnt cover. it wont be much but if there is any you need intake gaskets. i think a dollar bill held over the hole will suck in towards it if you have a leak.
Old October 30th, 2006, 04:04 PM   #10
kevinr839
kevinr839's Avatar
Default Thanks for the diagnoses
Are we talking about trucks or women???
kevinr839 is offline   Reply With Quote
Old October 30th, 2006, 04:16 PM   #11
71jeepster
71jeepster's Avatar
i think i will just check it and change the gaskets, i already have 150000 so who knows if i get another 100000 for the change it will be a cheap fix, what exactly is the plenum anyway?
Old October 30th, 2006, 04:44 PM   #12
84Scrambler
http://www.apsprecision.com/billetplenum.html
Picture the bottom of a beerkeg style intake. This bolts to the bottom of it to seal it from the air intake area. This link is the middle level fix I suggested. It's a thicker billet plate (overpriced, but much better than the stock piece). The stock piece is probably 1/4 as thick as this plate. The stock piece gives too much and lets the gasket blow out. The Mopar intake doesn't have the plenum like this. It's all one solid piece, so it would never leak. Just up to you how much you want to spend fixing it.
Old October 30th, 2006, 05:02 PM   #13
71jeepster
71jeepster's Avatar
that don't seem like that bad of a price, since it comes with all the gaskets, and new bolts, it's probably 50 to 60 bucks just for the gaskets
Old October 31st, 2006, 09:58 PM   #14
Grandman
do i look old !
Grandman's Avatar
I was thinking along these lines as well . Does it tend to roll blue smoke if you shut if off for an hour or two then restart it ? Thats oil getting down the valve stems . That kind of miles the guides are getting loose and the valve seals are getting hardened .
Sounds like some one ran Pennzoil in it
Old October 31st, 2006, 10:11 PM   #15
71jeepster
71jeepster's Avatar
not me i hate pennsoil, i was using royal purple in it, but cant afford to feed it that every 1000 miles so now i dump the cheapest shit i can find until i get it fixed
Old October 31st, 2006, 10:13 PM   #16
fordf250man
fordf250man
fordf250man's Avatar
my buddy had a 98 ram and it was burning oil like that, the valve seals were bad.
fordf250man is offline   Reply With Quote
Old October 31st, 2006, 10:17 PM   #17
71jeepster
71jeepster's Avatar
that's what i thought it was, but i'm gonna try the plenum gasket first
Old November 1st, 2006, 01:58 PM   #18
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
Don't mean to litter in this thread, but my brothers 3.9 dakota does the same thing. Do those engines have the same problems?
thanks
RIP FULLSIZE4LIFE
Old November 1st, 2006, 02:10 PM   #19
71jeepster
71jeepster's Avatar
i'd say yes it could very well be, sounds like it's a problem for all the magnum engines, click the link that 84scrambler posted and it is listed as a repair item for them also
Old November 21st, 2006, 10:41 AM   #20
71jeepster
71jeepster's Avatar
fixed it yesterday, could see where the plenum gasket was blown out!!
thanks for the help!!
Page generated in 0.38050 seconds with 83 queries
